98gtawd Posted March 27, 2011 Share Posted March 27, 2011 ok so i got a ej25 in my 98 lgt, do theses got two cams or one? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 4 Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 27, 2011 I Donated Share Posted March 27, 2011 its dual over head cam....meaning there are two cams per head...and you have two heads, so you have 4 cams all together. And you're engine isn't just an EJ25. Its an EJ25D -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 so we do have the 25d engine. even though they say ej25 Link to comment Share on other sites More sharing options...
DelawareBlueHen724 Posted March 27, 2011 Share Posted March 27, 2011 I was new to Subaru, and thought all 2.5's came DOHC, so I was confused to the whole EJ25D and EJ25 thing too lol Link to comment Share on other sites More sharing options...
subikid90 Posted March 27, 2011 Share Posted March 27, 2011 EJ25 is just the block stamp. Every EJ25 has that stamping. Subaru has had many EJ25's, EJ25D, EJ251 EJ253, EJ255 and EJ257. EJ251/3 is pretty much the same block, just an updated EJ25D. EJ255/7 is a semi closed version of the EJ251/3. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted March 27, 2011 Share Posted March 27, 2011 i has teh EJ25DE Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 ok thanks i'm new to subaru so ya... lol and whats the difference between the ej25 and the ej25d? Link to comment Share on other sites More sharing options...
subikid90 Posted March 27, 2011 Share Posted March 27, 2011 The EJ25D is a specific version of the EJ25.EJ25 just tells you it is a 2.5l motor, the 'D' or '1/3/5/7' tells you the rest of the info like bore, stroke, etc. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 it does? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 well how can you tell then what ej25 you have.. cause my sedan has a swap and i wanna know if i has 1 or 2 phase 1 engines. which are the blocks that were used for turboing with sti internals. haha Link to comment Share on other sites More sharing options...
subikid90 Posted March 27, 2011 Share Posted March 27, 2011 http://en.wikipedia.org/wiki/Subaru_EJ_engine And I meant to say bore/stroke is the same for all EJ25's, compression ratio is what changes with the model. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 ok and is there any books on these cars/motors? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 other things change to. like open deck vs closed deck, cylinder wall thickness. Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 other things change to. like open deck vs closed deck, cylinder wall thickness. So the wall thickness is different in the ej25d and are they a closed or open deck? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 there are 2 verisons of the ej25d in america. both are open deck but one has thicker cylinder walls. the phase 1 i think. Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 how do u know which one you got Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 i have no clue. thats what im trying to find out. the ej25d in the 96 made 155 hp and the ej25d in the 97-99 made 165 hp Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 ya i knew that much lol Link to comment Share on other sites More sharing options...
johnegg Posted March 27, 2011 Share Posted March 27, 2011 if your engine is original to the car, the id tag on the driver strut tower will tell you. it will say EJ25Dxxxxxxxxx or EJ251xxxxxxxxxx. in the early ej22s only the turbos had a closed deck design. i don't know if that is also true for the ej25s. Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 Ok but how u know if its a phase 1 or 2? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 yea. thats what i really wanna know. that one guy ran 35 pounds of boost on the phase 1 ej25d block with 8.1:1 CR. made like 400 plus whp Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 Dang but ya i would like to know how to find out what phase Link to comment Share on other sites More sharing options...
subikid90 Posted March 27, 2011 Share Posted March 27, 2011 If your coil pack is female then you have phase I, if it is male then you have phase II. I hope you know that he was lucky to pull that power from an EJ25D. He also had the tune down to an art, which is 90% of the reason engines blow when forced induction is added. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
98gtawd Posted March 27, 2011 Author Share Posted March 27, 2011 O ok Link to comment Share on other sites More sharing options...
