2005 LGT Wagon TD05-20G
Event: Dyno Pull
Loaction: ESP, Sterling MA
Date: 9/16/12
Ambient Temp: 70 degrees F
Elevation: Approx. 100ft
Weather: Sunny
Car: 2005 Subaru Legacy GT
Tuner: Me
Dyno Info: Mustang
Transmission: 5 speed MT
Gear: 3rd or 4th
Peak Horse Power at RPM: 292@ approx. 4200rpm
Peak Torque at RPM: 292@ approx. 6200rpm
Baseline hp/tq for a stock on same dyno: stock LGT 195WHP
Target Boost: 19.5psi
Target AFR: 10.8ish
SAE Correction factor: ?
Fuel: 93 octane
Engine/Power Modifications: Kinugawa TD05-20G, IPR TMIC, K&N Typhoon, Perrin turbo inlet, Grimmspeed EBCS, Forge BPV, Grimmspeed EWG Uppipe, CNT catted downpipe, DW 850cc sidefeeds, Walbro 255
Driveline Modifications: stock
Suspension Modifications: Cobb front/rear sways
Other Modifications: 17x8 Rota’s 235/45/17
Still have more HP left on the table. I need to check my wideband as the dyno's AFR shows I was running richer than my target. On the street I reach full boost by 3500 RPM's.
  • 4 weeks later...
Boost target is a little low for 93 octane. I'd leave your AFR's alone and bump your target to 21-22psi.
You would see a nice bump in power and still a safe tune. Probably a 20-35 gain all around.
[URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL]
