ThatGuyFromAus Posted November 23, 2012 Share Posted November 23, 2012 Hi guys kinda a multi question post What spark plugs should I use when i go to replace them shortly Thinking NGK Iridiums or V or G Power (what's the difference?) Ill do them when I do the MSD coil upgrade with FX61 leads which I believe to be the right ones? Will I notice much of a difference if i did MSD coil,leads and plugs and possibly Intake spacers Thank you for any help in advance Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 23, 2012 Share Posted November 23, 2012 Will I notice much of a difference if i did MSD coil,leads and plugs and possibly Intake spacers NGK platinums are usually sufficient & yes, you will notice the difference from the MSD coil right away from the sound of start up. Reset your ECU before installing it though. The intake spacers keep the intake air as cool as possible & yes, they do work. I have a set from Grimmspeed & they do my EJ22 justice. Link to comment Share on other sites More sharing options...
Grimmrican Posted November 23, 2012 Share Posted November 23, 2012 If ur car doesn't come with oe iridiums then don't put iridiums. Just a waste of 7$ea. Ngk g power is platinums and v power I believe is resistor/copper cheapies but goodies. Def better than autolites. In my car I run Denso platinum tt. Runs great with my all stock setup lol Link to comment Share on other sites More sharing options...
zangado1 Posted November 24, 2012 Share Posted November 24, 2012 NGK allday,everyday in Subies....... Link to comment Share on other sites More sharing options...
fildigger Posted November 24, 2012 Share Posted November 24, 2012 NGK allday,everyday in Subies....... As above..no brainer! Tapatalk from Galaxy S2 Link to comment Share on other sites More sharing options...
LJ08GT Posted November 25, 2012 Share Posted November 25, 2012 NGK allday,everyday in Subies....... YUP What he said!! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 25, 2012 Share Posted November 25, 2012 what about E85 in our engines? BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted November 25, 2012 Share Posted November 25, 2012 NGK V Power! -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted November 26, 2012 Author Share Posted November 26, 2012 NGK platinums are usually sufficient & yes, you will notice the difference from the MSD coil right away from the sound of start up. Reset your ECU before installing it though. The intake spacers keep the intake air as cool as possible & yes, they do work. I have a set from Grimmspeed & they do my EJ22 justice. when you say 'reset' do you mean disconnect the battery or clear the codes its an OBD 1 system Link to comment Share on other sites More sharing options...
Grimmrican Posted November 26, 2012 Share Posted November 26, 2012 when you say 'reset' do you mean disconnect the battery or clear the codes its an OBD 1 system Yes Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 26, 2012 Share Posted November 26, 2012 when you say 'reset' do you mean disconnect the battery or clear the codes its an OBD 1 system Both. You can clear the ECU by disconnecting the negative cable from the battery & stepping on the brake pedal a few times (15-20). When you plug in the negative cable & start the car, it should automatically jump to 1500-2000rpms & work it's way down. Link to comment Share on other sites More sharing options...
spooln30 Posted November 27, 2012 Share Posted November 27, 2012 Where can you get the MSD coil for our cars? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 27, 2012 Share Posted November 27, 2012 Where can you get the MSD coil for our cars? eBay. Link to comment Share on other sites More sharing options...
spooln30 Posted November 28, 2012 Share Posted November 28, 2012 I found that we use the Neon coil. Thx Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted November 28, 2012 Author Share Posted November 28, 2012 Ok another question, Im thinking of doing the grounding mod making up my own kit what gauge wire should I use? should i just replace the original wires back to the original position or ground to a central point? Any other areas i could ground that may help? Thanks for any help Link to comment Share on other sites More sharing options...
twisty Posted November 28, 2012 Share Posted November 28, 2012 if youre not going to use 8G or better i wouldnt really bother. i also would at least clean the original grounding points and maybe replace with a heavier gauge before adding extras. this is all hindsight, since i already did the grounding mod and had very weak results, operation-wise. Link to comment Share on other sites More sharing options...
Bassnectar Posted November 30, 2012 Share Posted November 30, 2012 if youre not going to use 8G or better i wouldnt really bother. i also would at least clean the original grounding points and maybe replace with a heavier gauge before adding extras. this is all hindsight, since i already did the grounding mod and had very weak results, operation-wise. there is a upgrade on youtube called the big 3 or something it is mainly oriented to get the maximum performance of your alternator for your sound system. It mainly is replacing your original battery and alternator grounds to 0 gauge wire. I am gonna do that on my wrx swapped legacy and then work towards adding additional grounds Link to comment Share on other sites More sharing options...
Grimmrican Posted November 30, 2012 Share Posted November 30, 2012 I'm happy with my small tweeters on the window and my pioneer speakers. I was never big into the sound of my ear wax rattling out of my ears. As long as I can here the vocals and some beats I'm good lol *shrugs*  ̄\_(^__^)_/ ̄ Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 30, 2012 Share Posted November 30, 2012 I did the grounding mod. I bought my kit from broknindarkagain a while back. I noticed an improvement. It's a good mod to do if you want to run a big sound system. I put two subs in my SS and the system would cut out because the ground was insufficient. Once I ran two more ground lines it worked again. The window tweeters are great! I also installed Pioneer coaxials. They are great for the price. NGKs all the way. NGK v-power for the 22T! Link to comment Share on other sites More sharing options...
twisty Posted November 30, 2012 Share Posted November 30, 2012 i agree, if youre going to power your sound in the car you need to do some mods to the grounding as well as use 4g+ for the amps. i wish i could put a better sound system in my car, but as it is i have the original subaru cassette player in mine. that wont be able to change for a while, too many other projects that are draining my cash flow. like 3 teenagers. Link to comment Share on other sites More sharing options...
stevenva Posted December 1, 2012 Share Posted December 1, 2012 If you're going to go through the trouble of a grounding mod, may I suggest going all the way and just do the big 3 mod. As the book says: Half measures availed us nothing. Use welding cable, It's better and cheaper. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted January 3, 2013 Author Share Posted January 3, 2013 Another question, what leads will I need to do the MSD coil, a part number would be helpful The engine is a Phase 1 2.2 with the part number RC-FX49 thats the leads on it now with the end that goes above the head not into it, Thank you for any help that can be offered Happy New Year! Link to comment Share on other sites More sharing options...
stevenva Posted January 3, 2013 Share Posted January 3, 2013 Another question, what leads will I need to do the MSD coil, a part number would be helpful The engine is a Phase 1 2.2 with the part number RC-FX49 thats the leads on it now with the end that goes above the head not into it, Thank you for any help that can be offered Happy New Year! Here is a link to a walk through on a phase 1 2.2 that does not use a donor harness. http://legacygt.com/forums/showthread.php/msd-coil-into-subaru-step-step-photos-152338.html?p=3216418 It's been over 2 years with no problems. You will need new plug wires since the MSD coil uses a different spark plug wire size. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted January 3, 2013 Author Share Posted January 3, 2013 thanks mate, I've come across that ages ago but couldn't find it again. would you happen to know the part number of the leads, if not are the leads for the 2.2 or the 2.5 I think in Aus it would be the 98 Lib cause the gen 3 came out in 99 Link to comment Share on other sites More sharing options...
