Cincy_Machine Posted October 8, 2007 Share Posted October 8, 2007 Don't know where to put this question/problem. I have a 97 LGT. I just had a replacement transmission, axles and wheel bearing put in all due to torque bind that fried my transmission. All fluids are at the correct level. I feel a vibration under load while in gear at idle say at a stop light. The vibration in not present in park or neutral. I also do not fell any vibration while driving. This vibration was not present before the transmission replacement What is cause this vibration? Aaron Cincinnati Link to comment Share on other sites More sharing options...
RaGe Posted October 8, 2007 Share Posted October 8, 2007 when was the last time you did a tune-up? OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
Cincy_Machine Posted October 8, 2007 Author Share Posted October 8, 2007 Only had the car for a month so I haven't, Oh I forgot that I also have a new coil pack. Link to comment Share on other sites More sharing options...
RaGe Posted October 8, 2007 Share Posted October 8, 2007 to put on ? or that they gave to you with the purchase of the car? also manual or auto? might want to consider taking out one of the plugs and take a peak at what they are looking like. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
Cincy_Machine Posted October 8, 2007 Author Share Posted October 8, 2007 to put on ? or that they gave to you with the purchase of the car? also manual or auto? might want to consider taking out one of the plugs and take a peak at what they are looking like. The car is an automatic and the trans work, axle was all work done under purchase agreement. So what should I look for when I pull a plug? Link to comment Share on other sites More sharing options...
Cincy_Machine Posted October 10, 2007 Author Share Posted October 10, 2007 The car is an automatic and the trans work, axle was all work done under purchase agreement. So what should I look for when I pull a plug? On the subaruoutback.org board they say its the aftermarket axels. I just don't understand how.. Link to comment Share on other sites More sharing options...
Tasio505 Posted February 17, 2011 Share Posted February 17, 2011 I have a '98 outback 2.5L that has done that same thing for some time. Just threw a rod at 250,000 miles though. Trying to get the replacement engine going right. I'll let you know if it still does it. Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted February 21, 2011 Share Posted February 21, 2011 Mine does it occasionally too if I'm @ idle...I just did a plug and pcv valve change...havent changed wires nor coil yet. If I move to neutral, it goes away. I'm in the dealer today to get recalls covered....I'll let you know if they find anything associated to the idle shake. Link to comment Share on other sites More sharing options...
Amp2345 Posted July 13, 2012 Share Posted July 13, 2012 Certain aftermarket new axles cause vibration at idle in drive. Should have rebuilt them. Link to comment Share on other sites More sharing options...
