leftcoast74 Posted July 28, 2011 Share Posted July 28, 2011 Has anyone ever heard of an ecu(ecm) getting fried from flashing it a handful of times? Link to comment Share on other sites More sharing options...
Kaos22B Posted July 29, 2011 Share Posted July 29, 2011 Sounds like bs Is it just the air pump code? How did they deduce it was the "ecu being fried"? What did you flash it with? How many times have you flashed it exactly? People flash their ecus 100x over without issue. Link to comment Share on other sites More sharing options...
Ferenczy33 Posted July 29, 2011 Share Posted July 29, 2011 Whoa! $1100!! I would definitely be headed for a second opinion. I would also ask the tuner. My first question to dealer would be that if the ecu were to fry from flashing, wouldn't it have fried while it was being flashed? If the flash was successful and everything was working fine, why would it suddenly just fry weeks later? Hope you get worked out. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted July 29, 2011 Share Posted July 29, 2011 Yeah, see if either Tactrix or Cobb will fix if for you. If it is bricked, you could probably get a used one for less $'s from car-part.com, ebay, or a salvage yard. Just have to have the dealer program it to your car. Link to comment Share on other sites More sharing options...
Tomkat1127 Posted July 29, 2011 Share Posted July 29, 2011 Yeah, I don't buy that dealer's BS either. If the flash was successful then something else caused the issue. ECM's can be fried but it's typically and more likely from a electrical short in the system. Is there any chance a wire got damaged or pinched in your upgrades? Link to comment Share on other sites More sharing options...
Types4 Posted August 2, 2011 Share Posted August 2, 2011 Some flashes (i know the cobb ones for sure) lock out access to the ecu. So if one try's to "read" it they won't be able to. Perhaps that is why the dealer thinks the ecu is fried. Link to comment Share on other sites More sharing options...
Tomkat1127 Posted August 2, 2011 Share Posted August 2, 2011 Just a thought.... If there was a short and it has not been fixed and they throw another new ECM at it.....Um, won't it be fried as well? Can't they trace the circuits maybe ohm it out? Link to comment Share on other sites More sharing options...
m sprank Posted August 2, 2011 Share Posted August 2, 2011 Just getting to my VM's Dave. I see you left one. I will check it and get back to you. Replacing an ECU with an existing electrical issue is a no go. Chances are there is a short. A wire somewhere or a ground. Link to comment Share on other sites More sharing options...
Kaos22B Posted August 2, 2011 Share Posted August 2, 2011 So, went to the dealer today. Connected to learning view and there were alot of different codes on there now. My dumb ass didn't take a screenshot so I'll list the ones I can remember. Yes, ive heard some tuners lock it out, thats defiantly not whats happening here Knock sensor high Tps sensor high x2 Intake manifold sensor high x2 Secondary air pump sensor high There were a couple more but I forgot them. I'm thinking there was a short & that messed up the ecu. I expressed my thoughts to the service manager about the short "theory" and he said if they put a new ecu on it they should b able to work it out. Lol, BS These sound like a shared engine ground has something wrong (short/ disconnected) Given that you recently had engine work done, I would start looking in those areas. You'll probably find something interesting if you start looking at all the wires carefully. Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 2, 2011 Author Share Posted August 2, 2011 @Mike didn't I hear u say before that if that if the air pump valve is stuck open to long that it has melted some wires before? Link to comment Share on other sites More sharing options...
m sprank Posted August 3, 2011 Share Posted August 3, 2011 No. Not me. But the main communication ground is located under your TMIC next to the starter. I have seen lowered cars drivers side front wheels rip the wiring harness when the fender liner was bad. I have seen the bulk head harnesses at the tranny shorted from rubbing. Seen a few oddities like this that caused mayhem. Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 3, 2011 Author Share Posted August 3, 2011 Well the cars not lowered that much but the tmic was installed shortly before all this happened. Car is still sitting at the dealer...vexing! Link to comment Share on other sites More sharing options...
m sprank Posted August 3, 2011 Share Posted August 3, 2011 Ground wore is big. Like 4 gauge big. Not something that is going to get cut. But could be loose, or covered in grease like I always see. Could be a million things. But highly doubt it is the ECU. CanBus communication requires a "drain". Meaning "noise" can interfere with comm. It can get touchy. Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 4, 2011 Author Share Posted August 4, 2011 So should I just tow it to u? Link to comment Share on other sites More sharing options...
m sprank Posted August 4, 2011 Share Posted August 4, 2011 You can... I would need to bring tools home from the shop to start on it. I would have to move cars around too. Wife will freak if she gets blocked in again. Also, my drive way is Super steep. Steep enough that a flatbed can not make it up without slamming the tongue into the ground and damaging my drive. We had to be ultra craetive and not very safe when we trailered the SpecB home and put her in the garage. My residence is not the best place to work on cars. It violates the homeowners too. Doubt I can get it in the garage as the less steep side was used for the SpecB. Never had a flatbed tow truck try to make a drop in the drive. I use my house as a drop off for customers. Then I bring them to the shop. I can tow the car. But my trailer has the wagon on it, so I need to land that. Plus the dually is in Palo Alto, so I need to borrow a truck. Link to comment Share on other sites More sharing options...
m sprank Posted August 5, 2011 Share Posted August 5, 2011 Let me call and see if my buddies truck is available to tow. Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 5, 2011 Author Share Posted August 5, 2011 Let me know. I'll compensate for the tow. Link to comment Share on other sites More sharing options...
Tomkat1127 Posted August 10, 2011 Share Posted August 10, 2011 So it's been over 6 weeks with no car, it's undriveable and still sitting at the the dealer. I haven't thrown any cash at them because I think there full of bs. I've tried to find someone else to look & work on it but no one wants to touch it, weird. I live in socal and can't get my subie fixed...vexing! This was my dd, I have 3 kids and work full-time, I'm screwed. Wow, that and your Stromung CBE is touching a CV boot. You just do not have any luck. I feel for ya....I replaced a front brake line on my truck last night just to have the main line that runs from the front to rear pop a leak before I could even move the damn thing:mad:. Sorry, about your situation. Hope it turns around quick for you. Let us LGT' ers know what we can do to help. Link to comment Share on other sites More sharing options...
m sprank Posted September 3, 2011 Share Posted September 3, 2011 It has major electrical gremlins. Could be ecu. But can not test with new ECU as I have to have key re-coded for ECU at dealer. That means towing car to dealer for a key. Never seen a ECU go bad before (on a Subie). If it is bad, why? What happened? Link to comment Share on other sites More sharing options...
leftcoast74 Posted September 3, 2011 Author Share Posted September 3, 2011 Yes, thats what i'd like to know, what happenend to it. It never had a single problem and then... All of the mods that were done to it were bolt on, its not like the engine's been torn apart. Maybe I'm just that unlucky % that has a ecu failure. Link to comment Share on other sites More sharing options...
