mlwarriner Posted May 23, 2010 Share Posted May 23, 2010 1995 legacy wagon. headlights work fine on dim. switch them to bright and they're gone. but if you leave them on dim, and pull the switch back toward the driver ("flashing the brights") they go to high beams. ????? Link to comment Share on other sites More sharing options...
Grinchy Posted May 23, 2010 Share Posted May 23, 2010 Did you get under the hood and check to make sure your relay is still working? I'm not 100% about Subaru's but my eclipse had a relay for the lights. Link to comment Share on other sites More sharing options...
subikid90 Posted May 23, 2010 Share Posted May 23, 2010 Your turn signal lever sounds like it is bad. There are metal contacts that turn the lights on and off and since your lights work when holding them on and not when locked on it makes me think that the contacts on one side have gone bad. Ive never replaced a Subaru turn signal lever but I have done it on other cars and its not too horrible. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
mlwarriner Posted May 23, 2010 Author Share Posted May 23, 2010 Did you get under the hood and check to make sure your relay is still working? I'm not 100% about Subaru's but my eclipse had a relay for the lights. haven't checked. will start there perhaps. Link to comment Share on other sites More sharing options...
mlwarriner Posted May 23, 2010 Author Share Posted May 23, 2010 Your turn signal lever sounds like it is bad. There are metal contacts that turn the lights on and off and since your lights work when holding them on and not when locked on it makes me think that the contacts on one side have gone bad. Ive never replaced a Subaru turn signal lever but I have done it on other cars and its not too horrible. from what i can find, replacing the turn signal switch is about 350 in parts, and labor that's beyond me (since you have to pull the steering wheel, and it's got an airbag). Link to comment Share on other sites More sharing options...
subikid90 Posted May 23, 2010 Share Posted May 23, 2010 junk yard wont charge close to that much. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted May 23, 2010 Share Posted May 23, 2010 junk yard wont charge close to that much. +100000000000000000, in the yards here, i can get everything needed for a 5 speed swap for like $250 with a perfect transmission Link to comment Share on other sites More sharing options...
something different Posted May 23, 2010 Share Posted May 23, 2010 you have a bad head light switch, easy to change, used should be cheap or repair yours. steering wheel comes off quite easily. tom Link to comment Share on other sites More sharing options...
