icee0711 Posted February 18, 2010 Share Posted February 18, 2010 Ive got a 2005 legacy 2.5i with manual climate controls. I just swapped out the stereo to a newer one for a auxiliary input. New part = # 86201ag72a. It was a clean and easy job yet for some reason my heater doesnt work now. Everything else is fine. What did i miss? I dont think it makes any difference that i used my existing ac interface in place of the new one.i tried using the newer one after i discovered the problem and same problem. Link to comment Share on other sites More sharing options...
schwinn Posted February 19, 2010 Share Posted February 19, 2010 If your new unit is not a manual-climate control system, then the HVAC system will not work. This is known (see my post her: http://www.legacygt.com/forums/showthread.php?t=131474) If the new one is manual also, then we'd need more information on what, exactly, is not working. If the heat-selector isn't providing hot air, then maybe the damper-cable for the hot-side isn't connected? Incidentally, it's better to post such questions in the appropriate sub-forum, rather than the general "car" forum (ie, the forum I linked to). Link to comment Share on other sites More sharing options...
icee0711 Posted February 19, 2010 Author Share Posted February 19, 2010 yeah sorry about that, i never really frequent this particular forum and i suck at navigating but the damper cable came loose. Link to comment Share on other sites More sharing options...
