Bobshaker Posted September 11, 2016 Share Posted September 11, 2016 Good afternoon. '98 legacy, 2.2, 251K Car runs like a champ then suddenly acts like a misfire. To the point of stalling at lower RPM's. After cranking 8-12 separate times, car will start and drive away almost like nothing happened. Mechanic replaced the "Mass Air Flow Sensor" and air filter 2 weeks ago, and the car still had minor misfire/hesitation. Now it's almost undriveable. I put in Lucas injector cleaner and mechanic put in some too. I looked at the engine in the dark and there were no evident plug wire crossfiring. The Code P0440 EVAP System Performance is still shows in the scan. Thank You, Bob Sheedy Albany, NY Link to comment Share on other sites More sharing options...
zangado1 Posted September 11, 2016 Share Posted September 11, 2016 Go to the junk yard and try throwing a used coil pack on it with some new plugs / wires. I would start there since the MAF has been replaced already. Cheap route to try. Link to comment Share on other sites More sharing options...
Bobshaker Posted September 12, 2016 Author Share Posted September 12, 2016 Thank you. Any other ideas to check out? Bob Link to comment Share on other sites More sharing options...
08SpecB_DE Posted September 12, 2016 Share Posted September 12, 2016 Clean the throttle body Check fuel pressure with the car off and running Link to comment Share on other sites More sharing options...
wtdash Posted September 13, 2016 Share Posted September 13, 2016 NGK plugs and wires are highly recommended (required, IMHO). Also, w/those miles the valves may need adjusted. The '98 2.2 has the screw adjustment. Valve clearance: Intake: 0.20±0.02 mm (0.0079±0.0008 in) Exhaust: 0.25±0.02 mm (0.0098±0.0008 in) Is your CEL ON? or is the P0440 a stored code? Read THIS and see attached. More P0440 Tips Here are some additional tips for dealing with P0440 codes: • After doing the compulsory valve check with the NSM or aftermarket test equipment, make certain the ports on the canister drain/vent valve are not physically damaged. The hoses may disguise this condition and you may misdiagnose a broken valve. • Prior to reconnecting the hoses to the new valve, confirm that there are no obstructions in the drain hose due to the damaged component.Evaporative Emisstions Testing.pdfValve Clearance.pdf Link to comment Share on other sites More sharing options...
GTEASER Posted September 13, 2016 Share Posted September 13, 2016 Clean the IACV (Idle Air Control Valve). There are Subaru IACV cleaning How-To's on YouTube. It's fairly easy and doesn't cost anything besides a can of SeaFoam. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Bobshaker Posted September 15, 2016 Author Share Posted September 15, 2016 Thank you for the responses. These ideas will give me some direction at least. It's not the coil pack. I swapped it out w/ one that I know is good. The CEL light is on and the code is what comes out. Link to comment Share on other sites More sharing options...
Bobshaker Posted September 16, 2016 Author Share Posted September 16, 2016 GTEASER called it. A can of Seafoam through the Idle Air Control Valve intake seems to have cured it. Almost purring like a kitten. A road test and there was no hesitation at all. Thank you for all the responses. Bob Link to comment Share on other sites More sharing options...
GTEASER Posted September 16, 2016 Share Posted September 16, 2016 Good deal! Do the SeaFoam treatment to the IACV again after another oil change or two. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Bobshaker Posted September 20, 2016 Author Share Posted September 20, 2016 My celebration ws premature. After the Seafoam treatment the car drove well--a 4 mi test. Later, I got in and drove about 10 mi and was lucky to get home with the same symptoms as before. I just replaced the plugs and wires and once again it warmed up nicely then became undriveable with a 2 mi trip. Any more thoughts? Bob Link to comment Share on other sites More sharing options...
GTEASER Posted September 20, 2016 Share Posted September 20, 2016 make sure the 02 sensor is good, and all the connectors/harness to it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
johnegg Posted September 24, 2016 Share Posted September 24, 2016 it sounds like a vac leak, except they usually cause staring problems as well as running problems check all the hoses under the hood and make sure they are connected. it also sounds like the running issues are triggered by the engine warming up and going into ''closed loop'', running on actual engine info instead of basic computer ''pre-start'' programming. if this is hte case it could be an O2 sensor or even your temp sensor. if the fuel ratio is wrong (o2) it will run crappy. if the engine is warm but the computer thinks it is cold, it will run crappy. but since you have an evap code i would look for hoses first. or maybe even the little gray filter in the vac hose that runs to the passenger side strut tower. no other codes? good luck. Link to comment Share on other sites More sharing options...
Bobshaker Posted October 4, 2016 Author Share Posted October 4, 2016 OK everyone. I think it's conquered. A second mechanic replaced the o2 sensor and cleaned electrical conections. Yes, he said the fuel ratio was all out of wack. It still ran poorly. Back to the first mechanic who replaced the "mass air flow sensor," under warrantee. It now runs almost as good as new. So it was a faulty replacement mass air flow sensor and maybe the o2 sensor. I want to thank everyone for making suggestions. They gave me some direction with this problem. Bob Link to comment Share on other sites More sharing options...
