sicklyscott Posted January 29, 2010 Share Posted January 29, 2010 I'm looking at doing a few track days this summer with my Miata. I am a bit worried about breaking the car at the track and not being able to drive it back home. For that reason, I was thinking of installing a hitch on the back of the wagon and renting a tow dolly for the weekend. I don't believe the tongue weight would be a problem, but what about the clutch etc? The Miata weighs in at about 2300 lbs, plus the dolly. Thoughts? Link to comment Share on other sites More sharing options...
rao Posted January 29, 2010 Share Posted January 29, 2010 That is not going to be pretty. IIRC, the towing capacity is 2700 lbs, so that will be one skimpy dolly, lights, etc. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
urfsin Posted January 29, 2010 Share Posted January 29, 2010 A lot of people will tell you not to, but IMO you can. Just make sure your clutch and brakes are in good shape. Slide It Sideways Link to comment Share on other sites More sharing options...
Laverne Posted January 29, 2010 Share Posted January 29, 2010 I dont recommend it. Just because you can, doesnt mean you should.. Imagine, this, your brakes fade, trailer (which I assume has no brakes) will be come a big push. Now you have limited braking, and 6000(including theLGT) running away.. Yeah not fun. Pick you up a decent Suv, or PU( heck even a ranger is a MUCH better option Link to comment Share on other sites More sharing options...
ehsnils Posted January 30, 2010 Share Posted January 30, 2010 If you have a trailer with brakes, yes, no big deal. Just drive carefully and keep a safe distance. Even with brakes on the trailer your braking distance can be longer. Surge brakes or electrical doesn't really matter, both have their pros and cons. Many rental trailers are also marked with top speed - like 45mph, and that's for a reason. Trailer without brakes is a big NO! The risk of a dynamic instability when braking is just too big. Where I live unbraked trailers may only be driven above 20mph if the weight is less than 1/6th of the car. And that's a good rule in my opinion. And depending on market the Legacy is rated up to 2 metric tons. If you have a dual range gearbox on your Legacy - use the low range area when starting. You can shift up later. That will make it easier on the clutch. Just expect that the fuel consumption on your Legacy will go up, and keep an eye on oil consumption as well. And a bogie trailer is also better since it's a lot more stable. Unfortunately they are also heavier. http://www.bedug.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=25604&g2_serialNumber=4 Link to comment Share on other sites More sharing options...
B-Power-B Posted January 31, 2010 Share Posted January 31, 2010 I would not recommend it either. With a towing capacity of 2,700lbs and your miata weighing 2,300lbs that only gives you 400 for the trailer. The only trailer that would weigh under 400lbs is a dolly which has no brakes. Also, just because your engine can pull it, does not mean your brakes can stop it. My opinion would be buy or rent a truck-it quite possibly would save you in the long run. Link to comment Share on other sites More sharing options...
ehsnils Posted January 31, 2010 Share Posted January 31, 2010 Also, just because your engine can pull it, does not mean your brakes can stop it. My opinion would be buy or rent a truck-it quite possibly would save you in the long run. Which is why I recommend a braked trailer - regardless of which vehicle that's towing it. Link to comment Share on other sites More sharing options...
B-Power-B Posted January 31, 2010 Share Posted January 31, 2010 And a bogie trailer is also better since it's a lot more stable. Unfortunately they are also heavier. http://www.bedug.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=25604&g2_serialNumber=4 I read what you recommended and I wasn't disagreeing. I was saying that the average flat bed trailer that has brakes will weigh more than 400 lbs (like the one you have pictured). Its just my .02 to not tow that much weight with a legacy. If the OP does decide to do so, Id like to hear how it went. Link to comment Share on other sites More sharing options...
dmanaenk Posted January 31, 2010 Share Posted January 31, 2010 How far is the track? Sounds like your Miata is streetable, so if the track is within 100 miles I'd simply buy a AAA membership that includes 100mile tows. 666 Link to comment Share on other sites More sharing options...
legacygtkc Posted January 31, 2010 Share Posted January 31, 2010 i think it can lol [ame=http://www.youtube.com/watch?v=U9bhus_1Oos]YouTube- A Subaru WRX STi pulls a semi stuck in the snow[/ame] Link to comment Share on other sites More sharing options...
Laverne Posted January 31, 2010 Share Posted January 31, 2010 something not quite right about that last vid Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2010 Share Posted February 1, 2010 OP I have a 97' Suburban that is set up to tow our 18ft open trailer, it's a great tow vehical. I'm looking to sell it. I have a bigger truck to tow with. PM me if your interested. I see your in NJ, I believe they have some of the strictest towing laws. You may want to do this right the first time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
