phildog33 Posted September 16, 2011 Share Posted September 16, 2011 Hey guys, Ive been trying to tune my 2005 Outback with swapping pills and doing the street/etune pulls for Shamar Infamous Tuning.. and its been 3 months and we havent made any progress. Each pill and combo is not creating enough boost to move forward with tuning Shamar recommended me to get the grimmspeed ebcs for my car. I just ordered it and was hoping for a little instruction on installing it. Are there any links that take you through a Legacy grimmspeed ebcs install? Thanks again And in this setup.. all the pills disappear right? Right now there is a 1mm pill in the vacuum line and im stage3, VF52 with everything else installed.. and im getting 15psi max Thanks for any help again Phillip Link to comment Share on other sites More sharing options...
angeltalin Posted September 16, 2011 Share Posted September 16, 2011 there is a video on youtube.com [ame=http://www.youtube.com/watch?v=H9KSMr0q0uY]GrimmSpeed Boost Control Solenoid Install - YouTube[/ame] StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
GTTuner Posted September 16, 2011 Share Posted September 16, 2011 Reducing you WG duty cycle tables about 30% should get you in a "tuneable" area. Remember the Grimspeed is a block type soleniod , where as the factory is a bleed type and is very slow to react at higher boost levels. You can use the Grimmspeed as a bleed type but they work much better as a block type. Link to comment Share on other sites More sharing options...
robitrice Posted September 16, 2011 Share Posted September 16, 2011 use the video...its what i used to install mine. its really not as hard as u think. just buy enough hose and route it well and you will be set Link to comment Share on other sites More sharing options...
phildog33 Posted September 16, 2011 Author Share Posted September 16, 2011 ok im ready to install it.. seems pretty easy and straightforward is the stock BCS for the Legacy/Outback in the same spot as the WRX though? I think for the legacy it would be hidden somewhere else p Link to comment Share on other sites More sharing options...
angeltalin Posted September 17, 2011 Share Posted September 17, 2011 no if i remember correctly its right infront of the intake manifold StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
sjwelna Posted September 20, 2011 Share Posted September 20, 2011 ok im ready to install it.. seems pretty easy and straightforward is the stock BCS for the Legacy/Outback in the same spot as the WRX though? I think for the legacy it would be hidden somewhere else p It's bolted to the IM on the passenger side, pretty much right on top. Definitely trim all your WG tables by 30-40% for initial tune or you will be overboosting. Tuning the grimmspeed ebcs is a piece of cake, it works really well. After tuning one of them on a stock turbo (td04) forester I'm completely sold on it. -Steve Link to comment Share on other sites More sharing options...
Infamous1 Posted September 21, 2011 Share Posted September 21, 2011 No pills and new hoses, if you get confused contact Mike or me. Link to comment Share on other sites More sharing options...
LouzGT Posted September 23, 2011 Share Posted September 23, 2011 that vid is for the 04-07 sti and 02-07 wrx youtube has one for our lgt's and 08+ wrx will probably be of more use to you link: [ame=http://www.youtube.com/watch?v=OPnxp3Zkohg]GrimmSpeed Boost Control Solenoid Install 08+ WRX/LGT - YouTube[/ame] Link to comment Share on other sites More sharing options...
phildog33 Posted September 23, 2011 Author Share Posted September 23, 2011 thanks guys, it was super easy to install and works great! Link to comment Share on other sites More sharing options...
angeltalin Posted September 23, 2011 Share Posted September 23, 2011 LouzGT thanks for the correction, i was unsure which to post i only watched the one i posted, but its not hard to spot the BCS after watching either video StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
m sprank Posted September 24, 2011 Share Posted September 24, 2011 Did you get it all worked out? Link to comment Share on other sites More sharing options...
Infamous1 Posted September 24, 2011 Share Posted September 24, 2011 Yeah I helped him through it... Link to comment Share on other sites More sharing options...
berkshire40 Posted September 24, 2011 Share Posted September 24, 2011 make sure you have the right bracket, mine came with the wrong one and it took 2 tries but GS made it right (thanks for the customer service) there is a pic on the forum somewhere, it bends down at a 45 and has a threaded mounting point Mod list & photos _ Link to comment Share on other sites More sharing options...
Arcteryx Posted January 26, 2016 Share Posted January 26, 2016 I just installed this, and it was straightforward *except* for the fact that one of the hoses that runs in front of the intercooler (I think it's the head breather hose?) sits almost completely on top of the high pressure nipple coming off the turbo. I was able to get the stock hose off without moving that hose, but getting the new line on was damn-near impossible without taking that breather hose off and pulling it out of the way. Link to comment Share on other sites More sharing options...
m sprank Posted January 27, 2016 Share Posted January 27, 2016 Epic thread resurrection. LOL. Link to comment Share on other sites More sharing options...
