Danger Posted July 29, 2012 Share Posted July 29, 2012 I'm installing my first gauge of any sort, and I have been searching for the exact info I need but have not been able to find it in one place. There also seem to be multiple methods for installation, below is what I thought was best and easiest. You will need the gauge, the cubby pod, and the vacuum tubing that comes with the gauge seems crappy, go buy 7-10 feet of 5/32" vacuum tubing from your local auto parts store, it only cost me around 90 cents per foot. You also need some basic shop tools and cable ties. The cubby pod comes with detailed instructions for removing your center cubby panel and installing the pod, that part is easy, I'm not going to bother reproducing it. I followed johnAWD's instructionsfor routing the vacuum tube through the fender, but deviated from there. If you have an auto tranny there is a wide open grommet in the engine bay where the clutch master cylinder would go, but with a manual tranny I found the fender route was best. After reading this thread I decided to follow m sprank's advice and tee off of the MAP sensor. This is why you need at least 7 feet of vacuum tubing. http://i.imgur.com/ZAtpq.jpg I installed the vacuum line filter and boost sensor inside of the interior fuse box. Here's a shot with the side panel removed. It's not rocket surgery, just tuck it inside. To fish the cable to go between the sensor and gauge I stripped a couple feet of Romex and used one of the 12AWG wires to fish between the fuse box and cubby opening. Now, for the part that I had the most trouble figuring out... the wiring. The main thing that threw me off was this thread First of all, nobody ever says where to connect the orange wire for dimming when headlights are on. Second of all, it is suggested that the white wire be connected to Fuse #26 for the power windows so that the gauge won't activate until the ignition is "On". I studied the FSM and came up with my own assumptions, and I confirmed them with a multimeter. I made my own diagram for the clock connector: http://i.imgur.com/WlZCJ.png The difference between pins 8 and 9 is that 8 does not receive voltage until the ignition is on, which is the same as the power windows using Fuse #26. Pin 1 does not receive voltage until the headlights are turned on (not DRLs) which would tell the gauge to dim at night. So, all of the wires you have to tap into are in the same bundle going to your clock. I believe all electric Prosport gauges use the same basic wiring scheme, so this should work for any of them. To connect the Prosport gauge's wires to the clock harness I used some quick splice connectors which look like this. You can buy them at your local hardware store but if you look around online you can get more for less money. Now, the PITA part is that the smallest they make these splice connectors is 18-22AWG which I found too big for the Prosport gauge's wires, and on top of that Prosport only gives you an inch or so of wire to work with. I soldered some 6" lengths of 18AWG wire from a computer power supply to the Prosport harness to make my life much easier. I forgot to take a picture of that, sorry Here's the gauge mounted in the pod. I still haven't figured out where/how I'm going to mount the control panel, I suppose I will have to drill a hole through the pod panel to feed the wires through. Anyway, not a big deal. http://i.imgur.com/6wg4L.jpg If anyone wants to verify the functionality of the gauge regarding the key positions, check out this quick video I uploaded here: [ame= ] [/ame] I hope this helps somebody out and saves them a lot of time. I spent 5 times longer planning this all out than actually doing the install. I'm going to attach all of these images below in case imgur ever dies. Link to comment Share on other sites More sharing options...
dspurgin22 Posted July 31, 2012 Share Posted July 31, 2012 Great write up! Just installed the same gauges, but im going to wire my control units back around to the fuse box area, they look tacky compared to the gauges in my opinion so no need to show them off in my case haha but looks great! ill get some pictures up of mine soon Link to comment Share on other sites More sharing options...
Danger Posted August 2, 2012 Author Share Posted August 2, 2012 Great write up! Just installed the same gauges, but im going to wire my control units back around to the fuse box area, they look tacky compared to the gauges in my opinion so no need to show them off in my case haha but looks great! ill get some pictures up of mine soon That's not a bad idea! I didn't want to totally bury the controls, but I didn't see myself using them that much either. At least tucked away behind the fuse panel I can access them if I need to. I may have to copy that idea Link to comment Share on other sites More sharing options...
dspurgin22 Posted August 2, 2012 Share Posted August 2, 2012 Yeah I finally finished it all up yesterday, the fusebox is a great spot for it plenty of space to do what you need but not look at the nasty control panel the whole time. Link to comment Share on other sites More sharing options...
DeathToad Posted March 24, 2013 Share Posted March 24, 2013 So is there a pinout somewhere that shows what 2,3,4, 5 and 10 do? I took out a Nav system and and put in a cubby since I"m installing an aftermarket HU that has nav, but I can only get the clock to work and the readout next to it gives an 'Err' message. Link to comment Share on other sites More sharing options...
quick4dr Posted June 19, 2013 Share Posted June 19, 2013 will an 07 outback navi fit and work in an 05 sedan that only had a cubby? Link to comment Share on other sites More sharing options...
wdkrobsmith Posted June 19, 2014 Share Posted June 19, 2014 Sorry to bump a dead thread. I'm following this one as a guide for a boost gauge on an 07 lgt. The wiring is a little different. There are 5 wires headed to the 10 spot plug. Blue/Red = constant Black/Yellow = ground Yellow/Red = ACC There is no violet. The remaining 2 wires are Black/White & Solid Blue Bl/W = -.1 w/lights off, .04 lights on w/dimmer @ bright, 11.42 w/dimmer @ dim Blue = .03 w/lights off, .04 lights on w/dimmer @ bright, 12.92 w/dimmer @ dim Which wire would you use for the orange prosport wire, thanks? Link to comment Share on other sites More sharing options...
fstaslp Posted June 19, 2014 Share Posted June 19, 2014 so will this make the gauge dim when the headlights are on? Link to comment Share on other sites More sharing options...
wdkrobsmith Posted June 20, 2014 Share Posted June 20, 2014 Yes it should dim when the headlights get turned on and should be adjustable with the dimmer wheel. Or at least I think. Link to comment Share on other sites More sharing options...
GrasshopperLGT Posted February 25, 2015 Share Posted February 25, 2015 I just did this and this helped EXCELLENT!!! Link to comment Share on other sites More sharing options...
RUMBLGT Posted August 1, 2017 Share Posted August 1, 2017 Op. Thank you for the awesome pinout. But there's a problem with the instructions. If you wire up the prosport Red wire to the constant voltage, the light will ALWAYS be on. No matter if the car is off. I just wired this up the first way and found the light staying on. Just thought I'd put this here so anybody using this can take the information and avoid my problem. Thank you again for the awesome write up. Link to comment Share on other sites More sharing options...
