LegacyWGTW05 Posted June 2, 2012 Share Posted June 2, 2012 I recently installed a down pipe, up pipe & exhaust mufflers on my car. I did the COBB AP flash to stage 2 +SF intake. The CEL light is on and the Cruise light blinks. I read on another thread to disconnect the battery which I already did after everything. I even hooked up the reader to the ECU and it said a sensor is not working correctly. Is it just 100 miles? Can anybody confirm this? Otherwise after 100 miles I will have to go find help. The other question is; Does anybody know of a heat shield to install on to an aftermarket down pipe? Or do you just have to modify some brackets out of metal for it to work? Any information would help. Thank you. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 2, 2012 Share Posted June 2, 2012 I recently installed a down pipe, up pipe & exhaust mufflers on my car. I did the COBB AP flash to stage 2 +SF intake. The CEL light is on and the Cruise light blinks. I read on another thread to disconnect the battery which I already did after everything. I even hooked up the reader to the ECU and it said a sensor is not working correctly. Is it just 100 miles? Can anybody confirm this? Otherwise after 100 miles I will have to go find help. The other question is; Does anybody know of a heat shield to install on to an aftermarket down pipe? Or do you just have to modify some brackets out of metal for it to work? Any information would help. Thank you. First, your AP has a code reader. This should tell you which sensor is broken. The next step is to make sure it is reconnected correctly. Probably the get or O2 sensor. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Max Capacity Posted June 2, 2012 Share Posted June 2, 2012 It could be the missing egt probe but I thought the stage 2 flash took care of that. you may need to go to Radio Shack and get a 2.2k ohm resistor. they are 5 for $1.25. Stick one in the connector on the fender well. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 3, 2012 Author Share Posted June 3, 2012 It said intake sensor, would that be the O2 sensor on the manifold possibly? Since I needed to take it off to install the up pipe? Or could it be the sensor on the up pipe? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 3, 2012 Moderators Share Posted June 3, 2012 Neither, I believe. O2 malfunction says just that, and the sensor in the UP is an EGT sensor. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 3, 2012 Author Share Posted June 3, 2012 So what intake sensor would it be? Any help is appreciated? I would like to know is it ECU just adjusting to the new pipes? Any ideas on a heat shield or none? Or build brackets to hold it? Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted June 3, 2012 I Donated Too Share Posted June 3, 2012 there are lots of aftermarket options for heat shielding. Please search Link to comment Share on other sites More sharing options...
shadowsports Posted June 3, 2012 Share Posted June 3, 2012 What's the exact Pxxxx code? Best heatshield is GrimmSpeed. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 3, 2012 Moderators Share Posted June 3, 2012 So what intake sensor would it be? Any help is appreciated? I would like to know is it ECU just adjusting to the new pipes? Any ideas on a heat shield or none? Or build brackets to hold it? I have my heatshield trimmed for fitment with an aftermarket downpipe. I'll sell it to you for $10 + shipping "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ruggerheist Posted June 3, 2012 Share Posted June 3, 2012 cobb, grimspeed are 2 of the most common heatshields. both will fit a DP or buy that guys^ Link to comment Share on other sites More sharing options...
ruggerheist Posted June 3, 2012 Share Posted June 3, 2012 also go with a turbo blanket too Link to comment Share on other sites More sharing options...
AZP Installs Posted June 3, 2012 Share Posted June 3, 2012 So what intake sensor would it be? Any help is appreciated? I would like to know is it ECU just adjusting to the new pipes? Any ideas on a heat shield or none? Or build brackets to hold it? What code are you getting? (number ). I take sensor is probably the MAF located by the air filter box. Did you remember to plug it in before attempting to restart the car? Or is it still disconnected? -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2012 Share Posted June 3, 2012 My oem heat shield fit fine with my invidia up/dp. Why can't you use the oem heat shield on the turbo ? I just wrapped my up/dp with DEI heat wrap when I had the engine out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
fahr_side Posted June 3, 2012 Share Posted June 3, 2012 My oem heat shield fit fine with my invidia up/dp. Why can't you use the oem heat shield on the turbo ? Really? I had the clip the top half some to fit it around the bellmouth on the DP. The lower half lost some important mounting points and would have flapped around so much I left it off. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2012 Share Posted June 3, 2012 To be honest I didn't do the install the first time. But I have had the heat shield off a number of times and had to cut it for the vf52, but I haven't noticed any other cutting done to it. I also haven't looked that hard. I'll have it off and the near future to put the gold heat shield tape in it. I'll take a closer look then. I do only use two bolts to hold it on, because there is a piece missing or rusted off. I think one of the bolts is broken in the inside hole if I recall. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 4, 2012 Author Share Posted June 4, 2012 What code are you getting? (number ). I take sensor is probably the MAF located by the air filter box. Did you remember to plug it in before attempting to restart the car? Or is it still disconnected? -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Code P2016 is what is says. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 4, 2012 Moderators Share Posted June 4, 2012 passenger side TGV sensor? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 5, 2012 Author Share Posted June 5, 2012 That's what I read on the computer after looking up the code. Any ideas how to fix it? Code P2016 Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 5, 2012 I Donated Share Posted June 5, 2012 IIRC, I had that code after an engine swap. You need the TGV position sensor (the thing that looks like a throttle position sensor). Someone on here who deleted their TGVs would probably have it for sale. I have an extra from when I bought all the TGV stuff from someone, but I'm keeping it as a spare for myself, sorry. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted June 5, 2012 Share Posted June 5, 2012 Make sure the connectors are connected. Maybe you knocked one of them loose installing your other parts. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 5, 2012 Share Posted June 5, 2012 Check none torts first. Then you can remove and clean em. If that doesn't work, you may need to replace em. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 5, 2012 Author Share Posted June 5, 2012 What is the part number for the TGV sensor? The dealer's by me want to sell the whole thing not only the sensor. Link to comment Share on other sites More sharing options...
SKYravefever Posted June 6, 2012 Share Posted June 6, 2012 Did you also make sure that the green test-mode connectors in the interior passenger wheel bay are disconnected? Page 3 of this: http://www.cobbtuning.com/v/vspfiles/files/support/accessport/quick_start_guides/APqsgNEWsubaruLR.pdf Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 6, 2012 I Donated Share Posted June 6, 2012 What is the part number for the TGV sensor? The dealer's by me want to sell the whole thing not only the sensor. Why are you buying this part new from the dealer when it's readily available used in good condition on the internet for pennies on the dollar? Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted June 6, 2012 Author Share Posted June 6, 2012 Well I am trying to find it online but a part number would help. I want to the dealer ask for the part number but its for the whole TGV motor parts & sensors. Link to comment Share on other sites More sharing options...
