grantLGT Posted November 22, 2011 Share Posted November 22, 2011 Ok so after I put my down pipe on, i've noticed a very annoying clunking sound when im on the break in drive at a stop light. "cars a 5eat" but when i put it in nuetral the clunking sound coming from my feet that i can feel stops. everything is tight, nothing loose. tranny mount, nothin I can find. Is it just my tranny dropping down and hitting my down pipe? its only at a stop. please help! Link to comment Share on other sites More sharing options...
bhinak Posted November 22, 2011 Share Posted November 22, 2011 mine does that and its a 5mt. its just the dranny hitting the dp. mine does it under load in 1st and 2nd gears. if anyone else knows something more feel free to chime in. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2011 Share Posted November 22, 2011 What name brand DP is it ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bhinak Posted November 23, 2011 Share Posted November 23, 2011 mine's stock Link to comment Share on other sites More sharing options...
grantLGT Posted November 24, 2011 Author Share Posted November 24, 2011 What name brand DP is it ? mines a catless invidia, it was a really tight fit. it is the trans hitting it, but its just soo annoying.. Link to comment Share on other sites More sharing options...
MooKz Posted November 24, 2011 Share Posted November 24, 2011 Solution: Go to Walmart or any local store of your choice, and purchase anything flat and rubber and you can either 3M it to the trans or DP or put a high heat adhesive on it. A friend tried it and for the most part, it works. The only way he hears it is if he is under the car listening like a bat hunting its prey. Hope this helps. I don't have this problem or I'd have already done it. Link to comment Share on other sites More sharing options...
