mike2006legacygt Posted March 26, 2013 Share Posted March 26, 2013 Hey everyone, I just joined this club and I'm a new member. I have a 2006 LGT manual. I am running cobb ap stage 1 with the stock exhaust. I have a few questions that I'm hoping that you guys can help me with. 1. Has anyone heard of using just a down pipe with engine management, with no exhaust upgrades? I'm trying to see if purchasing a cobb down pipe and running the stage 2 will work. I've been told that the stock lgt exhaust is free flowing from cobb and I should have no issues. I've never heard of anyone having this set-up. Yes, the exhaust will be quieter, but will it perform almost as well as an upgraded non-stock cat-back? Thoughts? 2. Can someone confirm that there is no pre-cat in the stock up pipe on the 2006 lgt? I've heard that starting in 2006, they removed the pre-cat so that the stock up pipe flows better. So, in upgrading to just a down pipe, I won't have to worry about messing with the up pipe. I have searched several times trying to get more info on these 2 items. Please help and thanks in advance. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 26, 2013 Moderators Share Posted March 26, 2013 Has anyone heard of using just a down pipe with engine management, with no exhaust upgrades? You'd be the first, let us know how it works out I have searched several times trying to get more info on these 2 items. Please help and thanks in advance. I definitely give you lots of credit for forming full sentences and using punctuation, but your search technique needs work. Loads of info already out there to answer your questions. Check out the stickies at the top of each subforum. I'll throw you a bone though--cobb downpipe plus engine management (a tune) will give you great results--probably the best bang for you buck possible. You WILL want to replace your up pipe as it has a cat in it (07+ is catless). Power increase from any "cat-back" (post-downpipe) modification will not be noticeable at stage 2 levels. Stage 2 is where you'll be with an aftermarket downpipe and a tune. I would also advise looking into reinforcing your stock TMIC or replacing it with an aftermarket unit. Increased boost and a plain-jane TMIC has been known to result in failures. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
O.C.D. Posted March 26, 2013 Share Posted March 26, 2013 Going this same route as we speak - COBB/Stage 2/No exhaust mod ------ yet. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 26, 2013 Moderators Share Posted March 26, 2013 Going this same route as we speak - COBB/Stage 2/No exhaust mod ------ yet. Same here, for the second time Will be replacing my up pipe and other bolt-ons here and there as well. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mike2006legacygt Posted March 27, 2013 Author Share Posted March 27, 2013 Thanks to all for replying. What's a TMIC? Sorry, trying to familiarize myself with he acronyms. Also, are you sure on the 2007+ years for the up pipe not having a cat? This is what I haven't been able to find any info on. I have read 2006+ from a tuning site. Thx. Link to comment Share on other sites More sharing options...
Brett Posted March 27, 2013 Share Posted March 27, 2013 nah. 07-09 has catless up-pipe. TMIC = top mount intercooler Link to comment Share on other sites More sharing options...
stuck686 Posted March 29, 2013 Share Posted March 29, 2013 catted dp with stock exhaust here. works great sound dece. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 29, 2013 Share Posted March 29, 2013 That and an up pipe will give you really good gains. Up pipe is cheap and easy to do at the same time. you can definitely get away with something cheaper than the Cobb dp if you don't want to spend that much. Link to comment Share on other sites More sharing options...
O.C.D. Posted April 2, 2013 Share Posted April 2, 2013 Did my COBB DP this last weekend. Pretty straight xforward for the most part. Hardest part was getting the dang O2 harness off the trans, lol. Anyway, with a Grimm UP, COBB DP and stock exhaust you would be hard pressed to recognize a difference audibly. I can definitely hear the turbo a bit more and that is cool. Only on the base map right is so I can't say anything about power but I hope it is a big jump from stage 1. Link to comment Share on other sites More sharing options...
ylime Posted April 10, 2013 Share Posted April 10, 2013 does anyone have a sound clip of this set up?? you say its hard to notice?? I tried looking through the sticky and on yotube but no luck. Link to comment Share on other sites More sharing options...
hybridandy Posted April 10, 2013 Share Posted April 10, 2013 Same here, Cobb catted downpipe, grimspeed uppipe and an Access Port with Cobb's Stage 2 93 Octane tune. Stock exhaust and stock intake (with a K&N filter and minus resonator). Works just fine (put at least 50k miles on my setup) but audibly, you won't notice a difference. With the windows down and the right situation, I can hear a little turbo noise but just driving down the road, you couldn't tell it wasn't stock. I bounced around buying a Cobb catback years ago but I like having a quiet car someday (I driven plenty that aren't). My '06 had an uppipe cat. I believe it was '07 when they replaced the cat with an air pump. Link to comment Share on other sites More sharing options...
evildriver Posted April 11, 2013 Share Posted April 11, 2013 Also, are you sure on the 2007+ years for the up pipe not having a cat? This is what I haven't been able to find any info on. I have read 2006+ from a tuning site. Thx. Couldn't you just go look at your uppipe to determine whether or not you have one? And why wouldn't you trust what someone says on a site specifically about this car against some tuning site? Link to comment Share on other sites More sharing options...
stuck686 Posted April 11, 2013 Share Posted April 11, 2013 does anyone have a sound clip of this set up?? you say its hard to notice?? I tried looking through the sticky and on yotube but no luck. [ame=http://www.youtube.com/watch?v=Alabb80d3k8]Legacy GT Stock exhaust w/downpipe - YouTube[/ame] Link to comment Share on other sites More sharing options...
rob-2 Posted April 12, 2013 Share Posted April 12, 2013 Just did a invidia catless to stock. Like the sleeper look. Works great. The noise change is just turbo under heavy throttle. Going to add an uppipe to avoid problems with the cat down the road. Link to comment Share on other sites More sharing options...
monstorr Posted April 18, 2013 Share Posted April 18, 2013 I just got my lgt and he had the cobb catted on stage 2 93 octane. I still need to get a catless uppipe and ditch the 2005 AP tune/tuner but all i hear is that turbo spoooooooool <3 Link to comment Share on other sites More sharing options...
Joker1315 Posted April 23, 2013 Share Posted April 23, 2013 I'm about to do this as well this weekend to my '08. Cobb catted dp, AP stage 2, but I also ordered the Cobb intake with the air box. Is an aftermarket intake NOT recommended on this stage 2 setup? Don't hear much about intakes other than Hybridandy's K&N filter... Link to comment Share on other sites More sharing options...
Brett Posted April 23, 2013 Share Posted April 23, 2013 it wasn't tuned with the intake on it, but you can go somewhere and have it tuned with the intake Link to comment Share on other sites More sharing options...
Joker1315 Posted April 23, 2013 Share Posted April 23, 2013 I was just going to use the AP tune with Cobb dp and Cobb intake. Hoping this combo won't pose any issues...? Link to comment Share on other sites More sharing options...
Brett Posted April 23, 2013 Share Posted April 23, 2013 no, it won't. it'll be fine. Link to comment Share on other sites More sharing options...
stuck686 Posted April 24, 2013 Share Posted April 24, 2013 I was just going to use the AP tune with Cobb dp and Cobb intake. Hoping this combo won't pose any issues...? there is a map to use if you have the Cobb intake Link to comment Share on other sites More sharing options...
Joker1315 Posted April 25, 2013 Share Posted April 25, 2013 Is that map for '08 LGT? On their site I checked out the maps and it looks like '06 or '07 was the last year for a map with Cobb intake, unless it was updated? Link to comment Share on other sites More sharing options...
