q2slinger Posted June 17, 2008 Share Posted June 17, 2008 Are cusco lower braces legal for street touring or street prepared? Here is rule regarding strut bars: 14.3.G. Strut bars are permitted with all types of suspension. Strut bars may be mounted only transversely across the car from upper right to upper left suspension mounting point and from lower right to lower left suspension mounting point. No other configuration is permitted. Additional holes may be drilled for mounting bolts. Only bolt-on attachment is permitted. Interior trim panels may be modified to allow installation of strut bars. Holes or slots may be no larger than necessary and may serve no other purpose. This does not permit any modifications to the frame or unibody beyond the allowed mounting holes. Link to comment Share on other sites More sharing options...
q2slinger Posted June 17, 2008 Author Share Posted June 17, 2008 some pics front brace: http://us.st12.yimg.com/us.st.yimg.com/I/yhst-49187380673845_2004_61951480 rear brace: http://us.st12.yimg.com/us.st.yimg.com/I/yhst-49187380673845_2004_61884946 Link to comment Share on other sites More sharing options...
whitetiger Posted June 17, 2008 Share Posted June 17, 2008 yes, thay are legal. i run them myself in ESP Link to comment Share on other sites More sharing options...
whitetiger Posted June 17, 2008 Share Posted June 17, 2008 the rule you have posted refers only to strut tower bracing. the lower arm bars are considered chassis stiffening and are totally legal. Link to comment Share on other sites More sharing options...
q2slinger Posted June 17, 2008 Author Share Posted June 17, 2008 I'm not seeing any allowences for chassis bracing below street mod/prepared:eek: Link to comment Share on other sites More sharing options...
Metal2You Posted June 17, 2008 Share Posted June 17, 2008 I was under the impression they would not be allowed in the street prepared class. According to this table chassis, frame and subframe reinforcements are not allowed in SP. http://www.sff.net/people/dburkhead/prepcompare.htm Link to comment Share on other sites More sharing options...
AKLGT Posted June 17, 2008 Share Posted June 17, 2008 You can't have them in Street Tire classes. Steet Mod, just about anything goes but PAX sucks donkey balls. As for ESP, I don't know. I'm pretty sure most of the guys here running control arms or braces run in SM. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
whitetiger Posted June 17, 2008 Share Posted June 17, 2008 Just looking over the rules here.. http://www.scca.com/documents/Solo%20Rules/2008_Solo_Rules_2.pdf Its actually not so clear. Are arm bars considered subframe connectors, or are they chassis stiffening? Link to comment Share on other sites More sharing options...
whitetiger Posted June 17, 2008 Share Posted June 17, 2008 I think its ok since the arm bars use factory mounting points, and can be considered, at least for the front one, a lower strut bar. For the rear, im not so sure. Link to comment Share on other sites More sharing options...
q2slinger Posted June 18, 2008 Author Share Posted June 18, 2008 Thanks guys. Thinking about doing a regional event next month and wanna make sure I'm legal. Link to comment Share on other sites More sharing options...
nKoan Posted June 18, 2008 Share Posted June 18, 2008 I always thought the answer was no to that question. The pictures in question don't seem to be mounted to more than just the lower suspension mounting points. Link to comment Share on other sites More sharing options...
