malvic Posted April 20, 2009 Share Posted April 20, 2009 So coming home today I got a check engine. Manged to limp the car into a parking lot and called home to ask my wife to bring the COBB AP. I got a code P2135 - Throttle/Pedal Position Sensor/Switch “A”/“B” Voltage Rationality. I did a search, but cannot fine exactly what this means and what the issue/fix is. Anyone know? Link to comment Share on other sites More sharing options...
rao Posted April 20, 2009 Share Posted April 20, 2009 The fix is to check out the electronic throttle body Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
malvic Posted April 20, 2009 Author Share Posted April 20, 2009 Thank rao, That was fast. Got some reading to do now. Link to comment Share on other sites More sharing options...
dorikin69 Posted April 24, 2009 Share Posted April 24, 2009 Check your floor mat. Link to comment Share on other sites More sharing options...
dorikin69 Posted April 25, 2009 Share Posted April 25, 2009 ^I'm dead serious. Is the hook that secures your floormat broken by any chance? My floormat slides around on occasion, and I got this exact same code. From what I understand, the TPS and TBPS communicate with one another, and, if there is some sort of discrepancy it will throw a code. In my case, I was depressing the throttle, but the floormat was stopping the pedal from its normal range of motion. Check engine light/limp mode/ the whole shebang. Link to comment Share on other sites More sharing options...
malvic Posted April 26, 2009 Author Share Posted April 26, 2009 Floor mat is good. I've got the WeatherTech. Any way, took it to dealer where they checked things out. They checked and cleaned the connections. Link to comment Share on other sites More sharing options...
