hi to all, i have a 98 ob wagon that has the 5 speed trans. and i need to see if you guy can help me out, or point me in the right direction, i have a problem with shifting when i have it in fifth it looks like it is in third and the shifter wobbles from side to side when in gear. any pointers
new bushing are not the complete answer you also probably need new linkage bushings or a new linkage i went through this myself your best bet is to get under the car and figure out what is sloppy i retrofitted my linkages with some welding to be tighter than oem, i know somewhere online you can get a new linkage part
http://www.ultimatesubaru.org/forum/topic/112521-97-legacy-sloppy-shifter-fix-howto/
a decent how to
EDIT: by linkage i mean shifter u-joint
Yeah its really a different feel, crisp and short..I put a shortshifter in my first gen wagon with the kartboy front linkage kit, I have yet to get the rear bushing bit I'm not sure if that rear bushing will make a bigger difference since the original bushing is in good shape.
