downero Posted January 19, 2007 Share Posted January 19, 2007 I used to have 235x40x18" on an 18" rim When the rim got whacked, I switched to 17" and used 215x45x17" I'm wondering, without making any adjustments, Can I use 215/225 x 50 x 17"? The key is 50series, instead of 45series. There are many potholes here, that's why I would like a thicker tire. Thanks. Link to comment Share on other sites More sharing options...
Xenonk Posted January 19, 2007 Share Posted January 19, 2007 215/50/17 Keefe Link to comment Share on other sites More sharing options...
downero Posted January 19, 2007 Author Share Posted January 19, 2007 215/50/17 Thanks. If I may repeat, I will not be making any adjustments with the wheel height. So if I can use 215, then I'll use the 225 for wider grip. This sounds stupid but in short: 235x40x18 = 225x50x17, with no adjustments made to the wheel Thanks. I was worried that the 50series might not fit/ bulge. Link to comment Share on other sites More sharing options...
Xenonk Posted January 19, 2007 Share Posted January 19, 2007 depends on your rim too.. using a 7" with a 225/50/17 is really too tall and too sloppy for the wheel to work well... a 235/40/18 sizing is as big as you want to go for stock struts.. you dont want to rub. Keefe Link to comment Share on other sites More sharing options...
downero Posted January 19, 2007 Author Share Posted January 19, 2007 Thanks! Link to comment Share on other sites More sharing options...
Vimy101 Posted January 19, 2007 Share Posted January 19, 2007 I used to have 235x40x18" on an 18" rim When the rim got whacked, I switched to 17" and used 215x45x17" I'm wondering, without making any adjustments, Can I use 215/225 x 50 x 17"? The key is 50series, instead of 45series. There are many potholes here, that's why I would like a thicker tire. Thanks. Yes. That is my winter set up (215) on ContiExtremes. However I do have the OEM Spec.B Bilstein suspension set up for that circumference. They are squishier than OEM feel but pumped up a few pounds they feel pretty decent. Link to comment Share on other sites More sharing options...
