solidkevlar Posted April 14, 2013 Share Posted April 14, 2013 today i got into my car and pushed the rear defrost and the horn came on tell i turned it off. so i decided to do it again once i got out of traffic... ya i felt like a ass as the horn blared for like 15 sec at a stop light. this time it took about 5 times before it did it again ,but every time i push it i can hear a click inside the steering wheel. any thoughts? Link to comment Share on other sites More sharing options...
MAP Posted April 14, 2013 Share Posted April 14, 2013 Sounds like some short. Youre going to have to get a wiring diagram that shows the wiring for both those functions to determine where the wiring comes close to each other. It sounds like the problem could be in the steering wheel if you hear something there. Im assuming both functions have their own relay. Its possible wire energizing the defrost relay is somehow also energizing the horn relay. Tough to figure out without checking a schematic, or cable harness/ connector diagram. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 14, 2013 Share Posted April 14, 2013 How old is the car battery ? These cars have been known to do strange things when the battery votlage gets low. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
solidkevlar Posted April 14, 2013 Author Share Posted April 14, 2013 its old i should change it ... Link to comment Share on other sites More sharing options...
mwiener2 Posted April 14, 2013 Share Posted April 14, 2013 If this is happening with the engine running, it's not your battery or a low voltage problem... unless you've needed to jump the car a lot. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
solidkevlar Posted April 14, 2013 Author Share Posted April 14, 2013 this stuff gets me scared . cause my old 300zx burned to the ground cause of electical problems.also my buddys golf gti vr6 they think his had something to do with the hids that got installed. my z car was stock, only had it 6 months Link to comment Share on other sites More sharing options...
solidkevlar Posted April 14, 2013 Author Share Posted April 14, 2013 no i started the car from a event in fargo, let it warm up, turned on the road and at the stop light i hit the defrost and it happend. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 14, 2013 Share Posted April 14, 2013 Mice My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 14, 2013 Moderators Share Posted April 14, 2013 Mice "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
solidkevlar Posted April 15, 2013 Author Share Posted April 15, 2013 i found out the problem my lil boy spilt his drink in the cup holder and it leaked threw on the wire connector so i had to take it apart and clean it all up i got it to stop...wife failed to tell me this the other day. Link to comment Share on other sites More sharing options...
InnocentGuns Posted April 15, 2013 Share Posted April 15, 2013 Glad you got it resolved. Link to comment Share on other sites More sharing options...
Chameleon Posted April 15, 2013 Share Posted April 15, 2013 Thats a sigh of relief ... Link to comment Share on other sites More sharing options...
ragman Posted April 16, 2013 Share Posted April 16, 2013 HA!! Somehow its always the wife's fault! Link to comment Share on other sites More sharing options...
ChachiFBaby Posted April 16, 2013 Share Posted April 16, 2013 This sounded like a VW forum for a bit... Link to comment Share on other sites More sharing options...
