Hello everyone, PA 2013 Legacy 2.5i 6 speed
New to me this 2013 2.5I I'm new to Subaru not to cars. Small improvements done so far Debadge the rear SUBARU LEGACY emblems,Blacked out front grill, Mud flaps removed from all 4 corners, custom built side splitters done myself are all i got so far. Ive had the car since Feb.21 2015 so a little over 2 months now. Hoping to get some springs and Koni Yellows as soon as wallet allows and then new shoes of course..:D Im not sensitive at all so feel free to comment anything good or bad, any feedback at all is more than welcome. My name is David.
  • Replies 54
  • Created
  • Last Reply
Please feel free to comment, good or bad any and all feedback is appreciated. i do have more detailed pics of how i did it, probably less than 100$ exterior pvc materials from home depot. Why you ask.?? Why not???
  • 1 month later...
I like the way it looks, I'd maybe want to modify it slightly if possible but no idea what the parts are.
Can you link to what you used? Was it PVC Siding? Did you mount it with glue or screw right through it?
http://images.tapatalk-cdn.com/15/06/25/8c1a213f7db9abd27f2656005c9cf458.jpghttp://images.tapatalk-cdn.com/15/06/25/0a1405e8d21f26dc844142873a5f9c23.jpghttp://images.tapatalk-cdn.com/15/06/25/0d4021e24a43ee9833909c3b17364fe9.jpg
Sent from my SM-N910T using Tapatalk
http://images.tapatalk-cdn.com/15/06/25/44264d1bb1f6599b50a1f8ae54e11161.jpghttp://images.tapatalk-cdn.com/15/06/25/9d8113a93025b6cca0bd2d0bf1248996.jpghttp://images.tapatalk-cdn.com/15/06/25/d4dda9e094a2a56efc5a9b6a9446270a.jpg
http://images.tapatalk-cdn.com/15/06/25/96e07049808985a38002d83a5837dfec.jpghttp://images.tapatalk-cdn.com/15/06/25/ea1e6889388761f31f531c7c75296520.jpg
http://images.tapatalk-cdn.com/15/06/25/ce3c998ad99fd916348a133725d093d4.jpghttp://images.tapatalk-cdn.com/15/06/25/f4bcfe114c20e8541d9ee59435b00221.jpghttp://images.tapatalk-cdn.com/15/06/25/c0afa24b4b3bf0af2e6188ac12b11895.jpg
Raw material was 78"x8" piece of outdoor pvc trim from Home Depot, luckily one side was kinda textured but the other side was smooth and had lines which made everything easier making sure it was even and straight. Stainless Steel bolts ,almost flat, go from the bottom of the lip through a washer-splitter-washer-side skirt-washer-nylon center bolts. Between bolts 3m double sided tape the wide kind. They are on with no real signs of any kind of wear or tear except the inevitable rock scratch here or there. I would definitely do it again and with a better shape if I had a dremmel or similar, but I only had a few hand tools and some sandpaper and spare time. When I get better tools I will make a improved version, maybe rounded edges...
Thanks for the pics and details! I was thinking the same thing about rounding out the edge but it looks great for a piece of PVC from home depot. I hope to try this as soon as I can find some time
  • 2 weeks later...
http://images.tapatalk-cdn.com/15/07/12/df43cb6806f2061bcc3fae9212711b98.jpghttp://images.tapatalk-cdn.com/15/07/12/6b782aa2f296dee517b612d3c1d1b999.jpg
Did you take the emblems off or do it right on the car? Looks good!
Right on, taped a small window around it and 4-5 thin layers of plastidip. Then it's just a matter of carefully removing the inside of the letters and the surrounding plastic around the outside of the letters. Took about an hour and a half with 15-20 mins of dry time between coats.
http://images.tapatalk-cdn.com/15/07/13/6c48d6fc7173fcf764042f64e8a5a810.jpghttp://images.tapatalk-cdn.com/15/07/13/7c9f37bc67fb6b33f8055b60da6a97db.jpghttp://images.tapatalk-cdn.com/15/07/13/367779a03e0326b1b96aa134f68a35cf.jpghttp://images.tapatalk-cdn.com/15/07/13/1ccfc25101ddcc3c85d465ea9721fcbb.jpg
Wet sanded 2000 grit very light, only one good coat, next up multiple clear coats before re-installing...
