bluewagon Posted August 20, 2010 Share Posted August 20, 2010 Can any one tell me the size of the wrench(s) I need to use to bleed the brakes on a 2005 Legacy? I read somewhere the front and back bleeders are different sizes. Thanks Link to comment Share on other sites More sharing options...
valerka Posted August 20, 2010 Share Posted August 20, 2010 As far as I remember they were all 10mm on my car, someone correct me if I am wrong. Link to comment Share on other sites More sharing options...
berkshire40 Posted August 20, 2010 Share Posted August 20, 2010 10mm is right I think. my brembos were 11mm Mod list & photos _ Link to comment Share on other sites More sharing options...
ehsnils Posted August 20, 2010 Share Posted August 20, 2010 Those nipples are always in a large number of dimensions and if you happen to have a refurbished caliper they can be in imperial measurements too. It's just a random selection of what happened to be at home for the moment in some cases. Just grab a collection of the small wrenches and try it out. Link to comment Share on other sites More sharing options...
GTTuner Posted August 20, 2010 Share Posted August 20, 2010 10mm wrench for the frt, 8mm wrench for the rear on a LGT. A 2.5i may be 8mm all around. Link to comment Share on other sites More sharing options...
GTTuner Posted August 20, 2010 Share Posted August 20, 2010 Those nipples are always in a large number of dimensions and if you happen to have a refurbished caliper they can be in imperial measurements too. It's just a random selection of what happened to be at home for the moment in some cases. Just grab a collection of the small wrenches and try it out. You said nipples? Where? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 20, 2010 Share Posted August 20, 2010 10mm wrench for the frt, 8mm wrench for the rear on a LGT. A 2.5i may be 8mm all around. Thanks GTTuner, I was going to say that, but I couldn't recall exactly. The only Subaru I have bleed the brakes on was the 99' 2.5RS that we sold last year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turbo_4Me Posted August 20, 2010 Share Posted August 20, 2010 You should have a selection of line wrenches in your tool set. 8, 10, 11, 12. You might see any combination of those sizes. Never use the open end of a open-end wrench or you will round out a tight bleeder. Link to comment Share on other sites More sharing options...
