waymanb Posted August 12, 2010 Share Posted August 12, 2010 I have a long block out of a 2009 spec b and was wondering if it will be a plug and play drop into a 2005 LGT. Im almost positive it will, just making sure. thanks Link to comment Share on other sites More sharing options...
rockle3 Posted August 12, 2010 Share Posted August 12, 2010 Hey are you doing this because you're engine blew or for upgrading? I dont think its much of an upgrade O.o or an upgrade at all Link to comment Share on other sites More sharing options...
waymanb Posted August 12, 2010 Author Share Posted August 12, 2010 no I have a 09 engine that im rebuilding and looking for a legacy to put it in. just making sure I dont buy an older year car and wind up screwing myself. Link to comment Share on other sites More sharing options...
waymanb Posted August 12, 2010 Author Share Posted August 12, 2010 so does anyone know if the heads are different at all? Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted August 12, 2010 Share Posted August 12, 2010 Almost all subaru base engines are similiar. the 09 engine will not work with an 05-06. In 07 subaru added an airpump on the engine for emissions, 07+ started using canbus so the ecu controls everything (wiring wont be the same) Link to comment Share on other sites More sharing options...
waymanb Posted August 12, 2010 Author Share Posted August 12, 2010 hmm.... I might be better off just selling the heads I have and just keeping the short block. Anyone want to buy some heads off a 09 spec b? they are like new, the car only had a few thousand miles on it. Link to comment Share on other sites More sharing options...
Strizzy Posted August 12, 2010 Share Posted August 12, 2010 Where are you located and how much? My bad luck build Link to comment Share on other sites More sharing options...
waymanb Posted August 12, 2010 Author Share Posted August 12, 2010 Im in northern KY near Cincinnati. I might keep them tho if they match up directly with a 06-07 wrx. anyone know if they do? Link to comment Share on other sites More sharing options...
waymanb Posted August 13, 2010 Author Share Posted August 13, 2010 bump Link to comment Share on other sites More sharing options...
