link138 Posted May 3, 2009 Share Posted May 3, 2009 I have a 2000 LGT 4AT, and around 65-70mph it is at 2800-3000 rpm's. Is that normal, is the converter not locking? Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted May 3, 2009 Share Posted May 3, 2009 My 5MT is about the same, maybe even higher, if that helps... Link to comment Share on other sites More sharing options...
Bdubs Posted May 3, 2009 Share Posted May 3, 2009 That's about right. The 5MT's tend to have slightly higher RPM's because they are geared differently. Link to comment Share on other sites More sharing options...
jonklein611 Posted May 4, 2009 Share Posted May 4, 2009 That's ballpark for mine, but mine's a 96 AT. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted May 4, 2009 Share Posted May 4, 2009 I think mine is around 3k at 70mph and 3.5k at 80? Ish? Link to comment Share on other sites More sharing options...
caschmidt Posted May 4, 2009 Share Posted May 4, 2009 thats exactly right. I have an 01 BE: 3000 rpm at 70mph. The torque converter IS locked. its at 3250-3500 unlocked Link to comment Share on other sites More sharing options...
Richard B. Posted May 4, 2009 Share Posted May 4, 2009 I have a 2000 LGT 4AT, and around 65-70mph it is at 2800-3000 rpm's. Is that normal, is the converter not locking? fwiw my 5eat at 80 is 2800 or so. at 100 is 3500. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted May 4, 2009 Share Posted May 4, 2009 Oh that's right, mine is a 2.5i, nvm Link to comment Share on other sites More sharing options...
link138 Posted May 4, 2009 Author Share Posted May 4, 2009 Thanks for the info guys, guess im used to my prior vehicle. (M6 + 3.42 gears =1600 rpm doing 65-70 mph) Link to comment Share on other sites More sharing options...
Platinum_Racing Posted May 5, 2009 Share Posted May 5, 2009 My torque converter locks if you stay about 45+ for a little while and don't goose the throttle too much. My Legacy is considerably older however.... Link to comment Share on other sites More sharing options...
fischer881 Posted May 5, 2009 Share Posted May 5, 2009 I have a 5MT at 3K rpms I'm at 67ish mph. Link to comment Share on other sites More sharing options...
eekay Posted May 5, 2009 Share Posted May 5, 2009 Yup. Pretty much the same. 68-70-ish MPH at 3K RPM (in 5th) and 3500 or so RPM at 80-ish MPH. Looking to swap out for a 6MT for an EJ some time in the near future. Or maybe just swapping out the gears. *shrug* My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
link138 Posted May 5, 2009 Author Share Posted May 5, 2009 Dumb question since I'm new to AWD, can you just swap ot the rear or front gears? Link to comment Share on other sites More sharing options...
eekay Posted May 5, 2009 Share Posted May 5, 2009 In all honesty, I haven't looked too far into the gear swap yet as I figure it would be easier to just swap the whole transmission. I would imagine that a gear swap IS doable as long as someone somewhere has gears that fit... *shrug* My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
link138 Posted May 6, 2009 Author Share Posted May 6, 2009 Interesting being this is my DD and it is auto, i wonder if i could change my gears since the auto only uses the rear wheels when the front begin to slip...hmmm OH GREAT SUBBIE GODS??? Link to comment Share on other sites More sharing options...
jonklein611 Posted May 6, 2009 Share Posted May 6, 2009 Are you talking about switching the diffs or the transmission gearing? Link to comment Share on other sites More sharing options...
eekay Posted May 6, 2009 Share Posted May 6, 2009 Are you talking about switching the diffs or the transmission gearing? I'd like to switch to switch the diffs. But, if that is not possible (which seems to be the case), I'm sure I'll end up switching for an EJ 6MT all together. You have any ideas? My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
link138 Posted May 6, 2009 Author Share Posted May 6, 2009 your lucky your manual already i wish i could have a six-speed Link to comment Share on other sites More sharing options...
jonklein611 Posted May 6, 2009 Share Posted May 6, 2009 I know subie has 2 diff ratioed diffs (like 4.3 and 4.6 or something) I'm assuming if you replaced both of them, it would be fine. Sl-i.net has a TON of swap info. I'd pop over there and search if I were you. Link to comment Share on other sites More sharing options...
eekay Posted May 6, 2009 Share Posted May 6, 2009 I know subie has 2 diff ratioed diffs (like 4.3 and 4.6 or something) I'm assuming if you replaced both of them, it would be fine. Sl-i.net has a TON of swap info. I'd pop over there and search if I were you. Will do. Thanks! My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
