MiniStiGuy Posted April 20, 2010 Author Share Posted April 20, 2010 Those are the AFS projectors so they will require custom mounting. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 20, 2010 Author Share Posted April 20, 2010 This is a Non-ASF http://legacygt.com/forums/attachment.php?attachmentid=33470&d=1173427299 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
NSFW Posted April 20, 2010 Share Posted April 20, 2010 Thanks. I looked up the thread where I placed the order and I did ask for the non-ASF version, and they did confirm that they have them... just a mix-up on their end. I've asked about an exchange. Will keep you all posted. Link to comment Share on other sites More sharing options...
NSFW Posted April 20, 2010 Share Posted April 20, 2010 They apologized, I'll be exchanging them for non-AFS. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 20, 2010 Author Share Posted April 20, 2010 Nice! OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ece_tim Posted May 7, 2010 Share Posted May 7, 2010 Thought I'd bring this one back. I bought my LGT with an RX330 retrofit and angel eyes done by the previous owner. Three problems: 1) Pass side headlight gets moisture in it. 2) Pass side headlight high (xenon) high beam doesn't work. 3) One of the CFL rings on the pass side headlight has come loose. Clearly I'm going to have to disassemble that light to get into this. Any tips on resealing to ensure it's moisture proof? Also I saw some mention of a cap that shouldn't be tightened too much, as it allows air to enter & leave the headlight? What is this? I understand there is a solenoid in the light that moves the cutoff shield for high beam activation. This solenoid could be bad, or there could be a wiring issue to blame. I can diagnose the wiring, but is there anyway to test or replace the solenoid? I'm not too worried about this, as I am unimpressed with the xenon high beams and will be upgrading the stock high beams & re-wiring those. I know the angel eyes/CFL rings are unrelated to the retrofit, but I also welcome any tips for properly securing these. I believe the previous owner used some type of adhesive - the kind that is yellow when it dries. The driver's side is fine, so I'm hoping if I can clean & prep all the surfaces really well, that a re-application will work. Any idea what adhesive to use? Link to comment Share on other sites More sharing options...
underpowerd Posted May 7, 2010 Share Posted May 7, 2010 ^re the moisture: reseal with high temp black rtv silicone. best luck with the other issues. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 7, 2010 Author Share Posted May 7, 2010 use the black high temp RTV the solenoid though if its broken you will have to source for the lights or just don't worry about it and leave them in the low beam position. Angel eyes you can remount with perhaps some clear high temp RTV or silicone but if you use silicone leave the lights apart for at least 24 hours so it can cure fully. Silicone if not left to cure will leave a haze inside your lights. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ece_tim Posted May 7, 2010 Share Posted May 7, 2010 (edited) Yeah if the solenoid is busted, I'm just going to disconnect the xenon hibeams. It could be wiring though - this guy didn't do the cleanest job. Black high temp RTV it is. Clean all the surfaces real well, maybe rough it up a bit, final alcohol swab? Thanks for the tips guys. Welcome any others for ensuring a one-time fix with this BTW - am I alone in thinking the bi-xenon high beams are unimpressive? Edited May 7, 2010 by ece_tim Link to comment Share on other sites More sharing options...
underpowerd Posted May 7, 2010 Share Posted May 7, 2010 maybe you could use the grey double-sided 3m mounting tape for the AEs? (i don't have even a remote idea of how they mount, but that stuff pretty much locks down everything i've ever thrown at it ). Link to comment Share on other sites More sharing options...
ece_tim Posted May 7, 2010 Share Posted May 7, 2010 Thanks, I'll consider that whenever I dive into these. I'm concerned over there not being enough surface area for tape, but thanks for the tip. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 7, 2010 Author Share Posted May 7, 2010 If I had to mount some angel eyes I would find something clear that can withstand high temps like maybe just krazy glue. Put it on let them sit to cure fully and touch up more if needed. As far as the sealing goes. Mine are using just the stock sealant but the high temp rtv will work great. You don't need to clean off anything if its the stock stuff there but if the other guy put silicone on then clean all that junk off. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ece_tim Posted May 8, 2010 Share Posted May 8, 2010 Yeah, a clear adhesive would be ideal. I'm just not familiar with adhesives, so I'll have to do my research. Link to comment Share on other sites More sharing options...
Hexs Posted August 12, 2010 Share Posted August 12, 2010 They apologized, I'll be exchanging them for non-AFS. Wondering how everything worked out with your install? Any issues with the kit from the Retrofit guys? Link to comment Share on other sites More sharing options...
NSFW Posted August 13, 2010 Share Posted August 13, 2010 They switched them out pretty quickly, but everything is still boxed up, I haven't gotten around to installing any of it yet. Link to comment Share on other sites More sharing options...
Biggu Posted August 23, 2010 Share Posted August 23, 2010 since im local to the retrofit source i stopped by their operation and picked up the stuff to do my retro. only thing i did different is i got the TSX lenses and wow what a difference. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 23, 2010 Author Share Posted August 23, 2010 yeah I run E30 Lenses in mine. My next thing is custom shielding which I might get to this week depending on the weather. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ece_tim Posted August 23, 2010 Share Posted August 23, 2010 Custom shielding? As, the low beam shield? To what end? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 23, 2010 Author Share Posted August 23, 2010 well I'm not happy with the shields that are in there now because they are flat so I am making custom curved shields so that the beam is sharp throughout the entire beam instead of just in the center as you get with a flat shield. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
yogis wagon Posted November 17, 2010 Share Posted November 17, 2010 I just received everything I needed for my RX 330 retrofit, but now I'm wondering something. I ordered a set of TSX-R lenses and when I opened the box, they actually ship the whole TSX-R projector. Now, am i still better of using only the TSX-R lenses in the RX-300 projectors or using the whole TSX-R projectors ? Witch set-up will give me the crispest and widest light output ? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 17, 2010 Author Share Posted November 17, 2010 the widest is definitely the RX bowls and they are also a direct swap with our stock ones so its also the easiest. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
yogis wagon Posted November 17, 2010 Share Posted November 17, 2010 Allright ! I also will try to make a custom curved shield. I'll post it up once it's done ! Link to comment Share on other sites More sharing options...
naimouasta Posted November 17, 2010 Share Posted November 17, 2010 how do you go about making a custom shield so that everything is focused and sharp. wouldn't that be kinda tough? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 17, 2010 Author Share Posted November 17, 2010 It just takes patience and its a trial and error thing. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Myevodream Posted December 10, 2010 Share Posted December 10, 2010 (edited) Ok, finally posting here after reading, and reading, etc... I am going to be attempting this over the holiday season (first retrofit), I have on order RX non AFS projectors with the TSX-R clear lenses. I know that the bowls should fit right in although I have 3 questions, 1) Do I have to order a conversion kit for the D2S bulbs, or just the bulbs themselves (I would imagine I have to order a kit to get from the wire harness that holds the H7) 2) I also want to black out the back, basically the opposite of clearing them, what kind of matte spray paint should I use, does it matter, I imagine high heat is a plus) Like the attached image 3) Best adhesive for putting the glass back on? Edited December 10, 2010 by Myevodream Link to comment Share on other sites More sharing options...
