polyarkos Posted May 24, 2014 Share Posted May 24, 2014 All 4 wires cut between the plug and the sensor by the drive shaft, we were in too much of a hurry and didn't route the wires properly. I've got a white, blue and 2 black wires to reconnect. Does it matter which way the black wires are connected i.e. are they specific? Thanks in advance. JP Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2014 Share Posted May 24, 2014 In the Gen Chat forum there is a thread about show me your vacation pix, that has a link to the manuals. May be you can find the manual there. http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FknBoss Posted May 24, 2014 Share Posted May 24, 2014 The 2 blacks are ground they don't matter which ones their connected to. The other 2 1 is a constant 5v supply the other is the signal from 02 to ecm. If you have a multimeter just touch black to a black wire and your red to another lead to see which is your power source. Link to comment Share on other sites More sharing options...
polyarkos Posted May 24, 2014 Author Share Posted May 24, 2014 Great, blue to blue, white to white, and black to black x2. I'll use spade connectors on the 2 black wires, if they need to be swapped its an easy fix before soldering the together. Link to comment Share on other sites More sharing options...
