Painting Wheels - Questions
A couple questions I have before I paint my snowflakes tomorrow....
1) Should I use aircraft remover or sand them down? It seems to me that sanding them down may take a lot longer due to the amount of spokes on these wheels
2) If I use the aircraft remover, should I use acetone after to remove any left over residue left from the remover? The acetone will also remove any moisture from the wheels.
3) I know people have painted these, so what have you done?
4) another painting question...just not wheels... thinking about Plastidipping my car white with a gloss coat because the previous owner thought it was a good idea to use 2 different colors of touch up paint. Anyone have any experience with plastidipping a car?
Any input is appreciated!
Is the original finish on your snowflakes in particularly bad shape? I'm no expert but I would think that paint stripper on the original finish might *not* be necessary unless you have bad chipping, flaking or peeling. Clean them up really well and see what you have. The picture in my head of the snowflakes surface up close is slightly textured. As suggested, you should probably scuff up the surface before fresh paint, but you may wish to consider doing that with some Automotive Scotch-Brite scouring pads instead of flat sandpaper. It would probably do a better job of scuffing the low spots along with the high spots on the original textured finish. I kinda see sandpaper just "scratching the surface" (pardon the pun). That is, it may sand down the high spots on the texture, but the low spots may remain unscuffed and the new paint might not adhere as well.
A light scuff with sandpaper or scotch brite is the way to go. That's what I have done. I cleaned them off with soap and water and then a auto paint degreaser. Then I sprayed the wheels with etching primer so the pain adheres to any bare metal. Next a few coats of color, and follow up with a few coats of clear. There is no need to sand between coats unless you have drips. But don't wait hours in between coats.
If you are painting the rims with the tires on buy a deck of playing cards and stuff them between the bead and the rim. It's easier than taping the tires.
Rattle cans work fine for panting rims if you have experience painting. I got some high quality paint made up at my local body shop. Two cans of color and one can of clear did it for me. They still look great and it's been over a year since I did mine.
So today I decided to tackle the painting job. Unfortunately, I wasn't able to finish them due to a few problems I ran into. Going into the project, I assumed that the wheels were just regular paint and I could use the aircraft remover to remove it down to bare metal. Well, I learned the hard way after the first "coat" of the remover. Took off some sort of a clear coat, and what do ya know, there was powder coat underneath that. The only thing I had on hand was acetone to try to remove that, and that worked to an extent. I was able to remove most of the powder coat but after I found out, I wasn't going to go all out like I wanted to. So I used a high 200's sand paper to remove the crappy spots of powder coat, then finally sanded them down with a 600 grit sandpaper. Even though they aren't down to bare metal, they are sanded down and ready to be painted tomorrow. I must say, it was quite the process sanding the snowflakes. Definitely not something that I would look forward to doing again! LOL
Finally all done with the wheels and they came out amazing. Some very little spots the are off but hardly noticeable. http://img.tapatalk.com/d/14/03/26/mazyraby.jpghttp://img.tapatalk.com/d/14/03/26/bu2utyga.jpghttp://img.tapatalk.com/d/14/03/26/ty3e7yha.jpghttp://img.tapatalk.com/d/14/03/26/e2egejyj.jpghttp://img.tapatalk.com/d/14/03/26/6asete2a.jpghttp://img.tapatalk.com/d/14/03/26/e2u9yzar.jpghttp://img.tapatalk.com/d/14/03/26/naza2y3a.jpg
Good job except for 1 thing, You spent all that time and effort and painted over the wheel weights. Please tell me I'm wrong and you did remove them first, painted them gold to match the wheels, and cunningly re-installed them in the same locations.
GodIhopeImwrong
RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles
GodIhopeImwrong
Unfortunately I didn't take the wheel weights off 🙈 when I get them balanced in the future, I will sand and paint that spot. Hopefully that won't be too hard...?
Looks great bro!! Good job
