CharlesC Posted October 18, 2012 Share Posted October 18, 2012 SO its getting cold where I live. Started getting this funky sound at startup first thing. Anyone have any idea what it could be? Is it bad? https://vimeo.com/51705513 Link to comment Share on other sites More sharing options...
lee07 Posted October 18, 2012 Share Posted October 18, 2012 Fuel pump maybe? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2012 Share Posted October 18, 2012 Could be the starter is starting to hang up, or the gear is slow to slide back from the FW. Its a common problem. Replace the starter. Or pull it, grease the shaft and put it back in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CharlesC Posted October 18, 2012 Author Share Posted October 18, 2012 If I replace Subaru OEM or Duralast? Link to comment Share on other sites More sharing options...
.Catalyst. Posted October 18, 2012 Share Posted October 18, 2012 Or pull it, grease the shaft and put it back in. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
ak legacy 49 Posted October 19, 2012 Share Posted October 19, 2012 Mine makes the exact same noise when it's cold! Link to comment Share on other sites More sharing options...
Max Capacity Posted October 19, 2012 Share Posted October 19, 2012 Or get a rebuilt starter from the auto parts store. That's what I did. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGT612 Posted October 19, 2012 Share Posted October 19, 2012 Could be the starter is starting to hang up, or the gear is slow to slide back from the FW. Its a common problem. Replace the starter. Or pull it, grease the shaft and put it back in. I agree with Max, except to me it sounds like the starter solenoid does not disengage like its supposed to when the car is started, and thus the hold-in coil in the starter is still energized allowing the flywheel to spin the starter motor instead of vice-versa. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 19, 2012 Share Posted October 19, 2012 I agree with Max, except to me it sounds like the starter solenoid does not disengage like its supposed to when the car is started, and thus the hold-in coil in the starter is still energized allowing the flywheel to spin the starter motor instead of vice-versa. You could hear that. I really couldn't hear much on that clip. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
