Mega Users LieutenantDan Posted May 9, 2011 Mega Users Share Posted May 9, 2011 I just recently had my shortblock replaced. I have an Infamous1 stage 1 tune and I was wondering if its necessary or just a good idea to get it re-tuned. I'm not too familiar with what engine parameters were used when I logged it. I don't recall seeing anyone else having done that. I've already PM'd Infamous1. I just wanted to make this for my and everyone else's reference. Thanks in advance. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 9, 2011 Share Posted May 9, 2011 Not absolutely necessary but you could if you want. The only time you NEED a retune if when you change the airflow a significant amount. Link to comment Share on other sites More sharing options...
Spec B Posted May 13, 2011 Share Posted May 13, 2011 I think it depends..if the tune was done when the car was healthy, I would just keep the existing tune infamous tune. However, if the tune was done while your motor was on the way out, you should get it retuned. In either case, log it to check if you are knocking. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 Review logs and see if it needs it. Like B said, if it was tuned when it was healthy, then nothing has really changed. It would be a good idea to know why the block failed in the first place. If it failed because of the tune, then I'd suggest getting the car retuned. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted May 13, 2011 Share Posted May 13, 2011 I'd at least request the original tuner to review a log or two, even if they want to charge for it. If a new tune is required it's a small amount and cheap insurance compared to the cost of replacing a motor. Link to comment Share on other sites More sharing options...
GTTuner Posted May 13, 2011 Share Posted May 13, 2011 Review logs and see if it needs it. Like B said, if it was tuned when it was healthy, then nothing has really changed. It would be a good idea to know why the block failed in the first place. If it failed because of the tune, then I'd suggest getting the car retuned. This. Link to comment Share on other sites More sharing options...
PoisonousBeef Posted May 13, 2011 Share Posted May 13, 2011 Review logs and see if it needs it. Anything else is pure speculation. Link to comment Share on other sites More sharing options...
