breadstick Posted May 25, 2013 Share Posted May 25, 2013 I can't find anyone else that is having this issue in a search. When I bought my car a few weeks ago, I got it used from a subaru dealership and they had just done an oil change before I bought it. I drove it home and around a few days, then after reading so much about our cars using oil, I got scared and checked mine. It was well overfull, up to the twist in the dipstick. I drained some out until the oil was right at the fill line. That was about a week and a half ago. I went out to check it this morning and the oil level was back up at the twist. The only difference is that the car had been warmed up and let to cool for 15 minutes after I drained the oil and rechecked. Today, the car was completely cold before I check. That shouldn't make a difference in oil level, should it? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 25, 2013 Share Posted May 25, 2013 Were you on an incline ? maybe you scrapped some oil of the side of the dipstick tube when you pulled it out. Sometimes the dipstick is hard to read and you'll have double check. Learn how your dipstick reads and where it levels out on both sides. No, the oil can't fill itself. Wish it did. Link to comment Share on other sites More sharing options...
breadstick Posted May 25, 2013 Author Share Posted May 25, 2013 Not meaning to sound crass, but I know how to read a dipstick and the crack about the oil filling itself was a joke. When I checked my oil both times, the car was parked on the level surface in front of my house. If it was off once, it would be off both times because it's parked in the same spot. Link to comment Share on other sites More sharing options...
Beanboy Posted May 25, 2013 Share Posted May 25, 2013 Oil temp does matter. There's even a hot full mark versus cold full mark. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 25, 2013 Moderators Share Posted May 25, 2013 Not meaning to sound crass, but I know how to read a dipstick No offense, but no you don't. Otherwise you wouldn't get the same reading after removing oil (unless the first check was with cold oil and the second was with hot, in which case you still don't understand fully how to check the oil). Best way to check the oil on these cars consistently / reliably is this: park the car on a level surface and pop the hoodpull the dip stick out a couple incheswait 10 minutespull the dip stick and wipe it with a rag, reinsertpull the dip stick and wipe it with a rag again, reinsertpull the dip stick and check the level on both sides. the lower reading is the correct readingreinsert / remove the dip stick again to check that you get the same reading. The above is assuming that you've been driving the car enough to completely warm the engine before checking the oil. I have to wipe the stick at least twice each time or I get false readings. Sometimes I also have to rotate the dip stick 90* to get the reading to be clear. Just the way things are with the oil pan / dip stick design. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Mr. Sinister Posted May 25, 2013 Share Posted May 25, 2013 ^ Instead of waiting 10 minutes, I've found that taking off the oil cap also works. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 25, 2013 Share Posted May 25, 2013 No offense, but no you don't. Otherwise you wouldn't get the same reading after removing oil (unless the first check was with cold oil and the second was with hot, in which case you still don't understand fully how to check the oil). Best way to check the oil on these cars consistently / reliably is this: park the car on a level surface and pop the hoodpull the dip stick out a couple incheswait 10 minutespull the dip stick and wipe it with a rag, reinsertpull the dip stick and wipe it with a rag again, reinsertpull the dip stick and check the level on both sides. the lower reading is the correct readingreinsert / remove the dip stick again to check that you get the same reading. The above is assuming that you've been driving the car enough to completely warm the engine before checking the oil. I have to wipe the stick at least twice each time or I get false readings. Sometimes I also have to rotate the dip stick 90* to get the reading to be clear. Just the way things are with the oil pan / dip stick design. Talk about stealing my thunder... OP your new to these cars. They are a PITA to get a true oil level reading. I normally wait 8 hours and check mine after work. I have also removed the o-ring on the top of the dip stick to help the vacuum or whatever release the oil back into the pan. If you think this is hard, wait till you change the tranny fluid. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 27, 2013 Share Posted May 27, 2013 There's even a hot full mark versus cold full mark. +1. A lot of people forget about that notch on the dipstick. Link to comment Share on other sites More sharing options...
apexi Posted May 27, 2013 Share Posted May 27, 2013 As barmanbean said, it's important to note that the oil level on the back if the dipstick might be different than the reading on the front. The reading on the front of the dipstick can be a lot different from the back too, not just a little. Also, I've had times where I've gotten two drastically different readings one after the other, read from the same side of the dipstick. Link to comment Share on other sites More sharing options...
iNVAR Posted May 28, 2013 Share Posted May 28, 2013 Here's something interesting I noticed recently... if you jam the dipstick in really quickly and pull it back out, the oil reading reads higher... Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 28, 2013 Mega Users Share Posted May 28, 2013 It fills itself. There's a reserve oil tank behind the intercooler. If the pcv valve gets clogged, it could overfill the oil instead of keeping it around the full line. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 28, 2013 Share Posted May 28, 2013 My specB refills itself with oil every 3,500 miles. It also regenerates a new filter, and there's a breath mint waiting for me in the cup holder when it's done. Link to comment Share on other sites More sharing options...
chimera Posted May 28, 2013 Share Posted May 28, 2013 Oh you bought one of those LGT magic spec's, wish I had one Link to comment Share on other sites More sharing options...
alegend90 Posted May 28, 2013 Share Posted May 28, 2013 Here's something interesting I noticed recently... if you jam the dipstick in really quickly and pull it back out, the oil reading reads higher... just the tip...just to see how it feels..... Link to comment Share on other sites More sharing options...
evil03mustang Posted June 4, 2013 Share Posted June 4, 2013 I had an old Crown Vic one time that had self-filling oil... Learned that oil floats on top of coolant and my bottom end was submerged in foamy greenish gray goo... when the connecting rods decided to perforate the block. Link to comment Share on other sites More sharing options...
