m_a_b Posted December 4, 2008 Share Posted December 4, 2008 I know this is probably a simple question, but I can't seem to find the answer. I guess searching for "can" doesn't yield anything real specific! so, help out a noob??? Link to comment Share on other sites More sharing options...
Napping Posted December 4, 2008 Share Posted December 4, 2008 Canadian dollars? Link to comment Share on other sites More sharing options...
987687 Posted December 5, 2008 Share Posted December 5, 2008 what context did you see it used in? Link to comment Share on other sites More sharing options...
m_a_b Posted December 5, 2008 Author Share Posted December 5, 2008 like if you go here: http://www.cobbtuning.com/info/?ID=3061 there is a download for a Subaru 2.5L user manual and a Subaru 2.5L CAN user manual I have also seen some online retailers list the accessport "2.5L w/ CAN" as in with CAN... Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted December 5, 2008 Share Posted December 5, 2008 CAN = Computer Area Network. The 'bus' part describes the interface with the assorted computer 'modules' within the network (car). Transmission, Engine, Traction Control.... can all share data. Link to comment Share on other sites More sharing options...
m_a_b Posted December 5, 2008 Author Share Posted December 5, 2008 so it has to do with datalogging? a couple more questions: 1) how does the AP map affect the si drive? Does it only flash the S# or all of them or does it make si drive useless? 2) do I HAVE to reflash the ecu or can I just do realtime so that if I want to go back to stock I can just unhook the battery? Are there any advantaged to one or the other? Link to comment Share on other sites More sharing options...
alaskajoel Posted December 5, 2008 Share Posted December 5, 2008 CAN = Computer Area Network. The 'bus' part describes the interface with the assorted computer 'modules' within the network (car). Transmission, Engine, Traction Control.... can all share data. It's actually Controller Area Network OP- You can read up here: http://en.wikipedia.org/wiki/CAN_bus Link to comment Share on other sites More sharing options...
DMTaylor Posted December 5, 2008 Share Posted December 5, 2008 Has nothing to do with datalogging. With a CAN network, all modules in the network receive all information. There are descriptor messages in the information. Each module looks at the information to see if it is for that module. If it is, it takes it in. If not, it passes it along. 1) does all of them 2) it stores your stock map before reflashing with a Cobb off-the-shelf map, so you can reflash to stock any time. unhooking the battery won't change anything Dave Link to comment Share on other sites More sharing options...
KartRacerBoy Posted December 5, 2008 Share Posted December 5, 2008 The AP is all seeing and all knowing. You have dingleberries. Wipe your can better, noob! Link to comment Share on other sites More sharing options...
m_a_b Posted December 5, 2008 Author Share Posted December 5, 2008 wait... how... DID YOU JUST HACK MY AP THROUGH THE INTERNET AND SEE THAT I HAD DINGLEBERRIES????! Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted December 5, 2008 Share Posted December 5, 2008 You get n00b points for that one. :lol: Link to comment Share on other sites More sharing options...
LGT Dave Posted December 5, 2008 Share Posted December 5, 2008 Ok back on topic...in the '07+ LGT's, Subaru changed the system that the car uses to communicate with all the various sensors and controllers throughout it to a CANbus system. So, when you see that Cobb is just referring to certain years of cars. For your other questions: 1) The SI Drive will still function just as it always has. Each mode will just have more power than it did before you installed the AP. If you get a custom tune from a tuner then they can make changes to each mode to make them behave any way you'd like. 2) The AP forces you to do a complete reflash when you first install (marry) it to the car. You don't have the ability to do realtime flashes until after you marry it. Link to comment Share on other sites More sharing options...
