Where are the engine grounds located?
I've searched all over this forum and the internet in general but cannot find a list of all of the grounds located in the engine bay on my 2007 Legacy.
The ones I've found are:
drivers strut tower
passenger head to chassis
drivers head to chassis
starter
pair at the front of the passengers side intake runner
Am I missing one or more?
Thank you all for the help with a trivial question
Two ground wires on the bracket in front of the master brake cylinder. Make sure they are clean before you attach them.
Engine Build - Click Here
There is a thread about replacing and making up the two lower grounds off the heads.
I thought I had a picture of the rear grounds, but couldn't find earlier this AM. I now I have it in my file on my home PC.
Signal wire to the starter is attached, and I am able to jump the starter with the battery. However, it won't turn over since there is no fuel. Starter wire gets 12v.
Max Capacity- I looked for those grounds but did not see them.
http://i1287.photobucket.com/albums/a635/frapcap/unnamed_zps5373e5a7.jpg
Top view of master cylinder.
http://i1287.photobucket.com/albums/a635/frapcap/unnamed3_zpsb2d44131.jpg
Ground on the front of the strut tower, behind the fuse box.
http://i1287.photobucket.com/albums/a635/frapcap/unnamed2_zps268c5ab8.jpg
View looking at the side of the strut tower at the only bracket near the master cylinder.
http://i1287.photobucket.com/albums/a635/frapcap/unnamed4_zps32ff007e.jpg
Another view of the same area, elevated.
http://i185.photobucket.com/albums/x40/92Si/DSCN4778.jpg
On the very left side, left of the water tubes for the heater core, you'll see two bolts, those are the grounds.
Went to take a look for those grounds and the bracket.
What year is that engine?
I dont have the bracket or any grounding cables anywhere near that head on my 2007 2.5i, n/a engine. The intake runners on the engine you posted are plastic. Mine are metal.
http://i1287.photobucket.com/albums/a635/frapcap/photo1_zpsb4324bd5.jpg
Photo of the drivers side head by the heater core hoses.
The only pair of grounding cables I have on my engine are in the front of the intake.
http://i1287.photobucket.com/albums/a635/frapcap/photo3_zpsb9c730f9.jpg
Thank you for the link.
Its missing the 2007 model, but I've been working off the 2008 FSM for a few weeks. Sure am glad someone saw fit to upload that to the web.
I'm really hating this effin' car.
The 07 should be the same as a 05-06 for the most part.
Or like you have been doing the 08 might have the 07. I have never looked.
