Legacybt 6mt Compromised Autocross Build
I'm building my dream do-everything car: ski rig, gear hauler, road tripper, autocrosser, and DD.
lGmqPIiVRjntoq79etxFuaA8tcxIyaeTjqAkCXulzTEFngPTDinWgO0QZf2wfY7keIIYtYb3O9sZVZiWgj8ZLabEwr1aBbFBhr97i8vtCopJ4j0VkavtV0F1QTDymNvkyJfuJMegvzmK5Orqu8QzomGWjUtfnaPrJ14gnv-XFuEhEdumf0QfxA-INXjIuNgjQQfcEkbUhwsaAHoxEHhkF-HWSNEnQ-rmQrx5EoXOalGiGt44XMlPBYhrArqdEo7ppbWEAmVNs9tecwBx1m5vf8eTv9yba7izN5cS8saYpScxlefHVldI58SOnBEjdIqyFTbY-9aebU0fRlcf8L1CL7YYJXoOdy-UwwgQ4p5o5F5CIUrLq8yru-RaMw3SyAL2OWUs--iL1w2Z17WTNONsKoN1ydtQagUN0KlzePRFwxcB-d_cb-3vzcStcPEC2oR3rIzjHyXpFHtyAsFn5NfJlZnRMq9qDezrxzgzhpbcdIUnNCcdDCtea-_4pPmsJVMgv1Xwtdh1bbD63PXW2bTdStaFRIIWtNJ8-GvaC8q6R3LKVTLcmTcjl2MsszLiti06VqZOO9LmMr4sLuONdo9QQGGQHsipMkqqhn1WU6t5vb3FCoZJLhse=w1224-h816-no
Back in 2014 I tore it apart for a major overhaul, and it's been under the knife a few times since then.
Engine - Current
VF-52 Turbo
CNT Catted Downpipe
Grimmspeed UP
Cobb SF Intake
Grimspeed EBCS
Forge BPV
DW65 Fuel Pump
DW 740cc Injectors
Bulletproof TMIC Mod
Group N Engine Mounts
Group N Pitch Stop
Group N Trans Mount
Borla Cat-back Exhaust
K2 Gear Spec Neo Dual Exhaust
Prodrive Oil Filler Cap
Stock Engine Cover :rolleyes:
Engine - Future
Killer B Oil Pickup - Purchased
Killer B Oil Baffle - Purchased
2008 Sti Oil Pan - Purchased
Crawford V2 AOS - Purchased
ID1000 Injectors - Purchased
Radium fuel pulse dampers - Purchased
Grimmspeed TMIC - Purchased
Custom TGV Deletes - Purchased
Tomei EL Headers - Purchased
Subtle Solutions Radiator Shroud - Purchased
Radium Top Feed Conversion Rails - Purchased
Rotated Uppipe and Downpipe with EWG Recirc
Garrett GTX2867R
Tial 38mm EWG
Company23 Anti-Surge EBCS
3.5" Custom Catback Exhaust
Surprises to come next spring/summer
Suspension/Steering - Present
Koni Shocks
Epic Springs
3/8" Saggy Butt Spacers
RCE Tarmac 1's 500F/450R Springs
AVO Sway Bar Reinforcement Brackets
Whiteline 24mm Front Sway Bar
Whiteline 20mm Rear Sway Bar
Whiteline Rear Camber Bushings
Group N LCA Bushings
Whitleline KCA334 Anti-Lift Control Arm Bushings
Spec B Strut Mounts
RCE Forged Lowering Camber Plates
JDM Sti Pillowball Toe Links
Whiteline KTA124 Camber Arms
Slotted Trailing Arm Mounts
Whiteline Steering Rack Bushings
Kartboy Endlinks
Whiteline Front Roll Center Kit
STI Solid Steering Intermediate Shaft
STI Strut Tower Brace
JDM STI "Front Support Kit"
SPT Lower Chassis Brace
Full Set of Spec B Aluminum Arms
Modified Trailing Arm Mounts
Transmission/Drivetrain/Shifter - Present
2002 JDM STi Transmission, Suretrac Front Diff
2004 USDM STi 6-Speed & R180 Clutch Pack Diff
2015 USDM STi Transmission & 2007 Spec B R180 Torsen Diff
DSS 27mm Shaft Rear Axles
Whiteline Diff Inserts
Exedy Lightweight Racing Flywheel
STI Stock Clutch
Cobb 6-spd STS
Cobb 6-spd Shift Knob
Redline Shifter & E-brake Boot
Kartboy Rear Shifter Bushing
Group N Rear Shifter Bushing
Kartboy Front Shifter Bushing
Group N Crossmember Bushings
Torque Solution Shifter Bushings
DCCDPro - Purchased, not installed
Brakes
Grimmspeed Master Cylinder Bracket
STI Brake Booster/Master Cylinder
DBA T3 Rotors
Hawk HPS Pads
Brembo Calipers F&R
DBA Rear conversion rotors
Centric Premium Front Rotors
DBA 5K 2-Piece Front Rotors
EBC 'Yellowstuff' Pads
Stock Brembo Pads
Stoptech Street Pads
Goodridge SS Brake Lines
Accessories/Interior - Present
Homelink Mirror
Raising Centre Console
Jazzy Aux-in Mod
STI Gauge Pack
Redlinegoods Black Leather Shifter and E-Brake Boots
WRX Pedals & Dead Pedal
JDM GR STi Recaro Driver's Seat
Accessories - Future
Zeitronix ZT-2
Audio
JDM Double DIN Radio Bezel
Pioneer Appradio4
Hertz HSK-165 and HCX-165 Speakers
Audison LRX6.9 Amp
ARC Audio XDI850.5 Amp
Kicker IQ1000.5 mounted under driver's seat
JL Audio 10W6V2-D4 10" Subwoofer in JL Stealthbox
Knukonceptz and Monoprice Wiring
Sound deadened front & rear doors, trunk
160 Amp Alternator
Footwear
Autocross:
JDM Enkei ES Tarmac 17x8 +45 with 235/40r17 Nitto Nt-01
DD/Summer:
Sport Edition KV5 18x8 +50 with 225/40R18 General G-Max
Rays Gramlights 57max 18x8.5 +45 with 255/40R18 Advan AD08-R
Rays Gramlights 57xtreme 18x8.5 +33 with 225/40R18 Direzza ZII
Rota Slipstream 17x8 +48 with 225/45R17 Ventus V12
Winter:
17x8 FRD POS Wheels with Hankook Icebears
Rota SVN 18x8.5 +44 with 225/40R18 Dunlop Wintersport
OEM Legacy GT 17x7 with Hankook Icebears
Rays Gramlights 57max 18x8.5 with 225/40R18 Michelin Pilot Alpin PA4
Appearance/Exterior
Custom painted headlights
Rev D-F JDM Tails
Bayson R Front Lip
Plastidipped Foglight Housings
JDM Rain Visors
OEM Aero Crossbars
OEM Trailer Hitch
This is what things looked like laid out on the floor before I pulled the car into its new home:
http://legacygt.com/forums/attachment.php?attachmentid=182513&stc=1&d=1400043403
http://legacygt.com/forums/attachment.php?attachmentid=182514&stc=1&d=1400043403
Keep posted for updates!
http://legacygt.com/forums/attachment.php?attachmentid=182531&stc=1&d=1400043841
zBem0kZ3943MZrxQU3vDJ_kAuBj-IspabEn_BSVCf8M5rxyOHDhyUqX2Q2xpfl4S8cQVYbUjCfpXBJi4CMcVqSjup78L_ZDdWi-VhZTs1Zv8WECOZ8SbHaAJ2BhCl0DHYUaYoQdqREVp352eYLcBzdawgPP4AfP1zftYCIyNVW8Sf9uQnqrRAvsklLXNQltxJxy9YjS1_oqVuJOnEFb9UGnvqY_LWuI_x6KQEWLCgBrKanKllNIB-jUOFB3lf6PSud3ovO0ZxbAEUXwQYxS7spWNItxljjdWmFuG3AZYbZzWbmOzQwFHs_iMw3bNVb3iNEQhLWQZuqnb7p_VZHBjFGLtUhCp5jY2yxR5e5JpHdP15p8jAxSIfpujv6wmBuGXZ42DOxoHltdD_cUWk5TCeMnxPyPlxk-ain0uQf1KDkwSQTwignOQLu4B1LpUoadGB2cDTGjpiRFxTKA1obsw4nC6HY7zvUmnMKCPV1RfBQXLidt0vjE93CT3AK6S3o8IkaZf0-JN3h1b0BWv1vap3WfLojckUV2Cgsqpe1wOpgQf2Sbzz1o63v-8Bw-nVkL5ioVUGESvHaUURKKrh9TQfY-ER0tm9A4iIrZzaowVWQy1PcKN17qiHNQOKDJAW6cNxmxs-kAxawLkJ5-vNHSBVjdX9eATvVF_5mhZVLhbxQ=w1224-h816-no
http://i.imgur.com/FjWmce9.jpg
fytnV43miwNFWe8GEmyKICokrBYw5l9Sn_Q1R5OcdlqQcSzWSR46KapqcY4-8xeWODyYzw-oA_F8revkTIN_xxNHUDUCthAznjZ0f5HP8Upqv3xb5GGpdhkUkwIVdqu2dToin7t7cM4b6UrF9MGE46LJz6Fl87BSNOutC8_IvnlE9iKlXxlM5Jr16Rnbe28HcQWqUphnypiXDPNLCUl3ugvt-V6jIFuB3uv67hovkfClUqhnoP2VSt-D4SajI8RzLimeiV5sYa1gTzejAYZKE6mSzRNw3rUe_DjMm6BRkvXh8t8MZKYrd0aNsPFmtp9_eiLWNlMehbbW2D4G-w3lwoc76lf1xgYaGvQO9M3emcWpFd9P0LG1PdEBa06MQQXXL59MufM0Zv7OweO7_BMsKxd5TwLeDLiawV23yM0_po2EXslJICiqz-Si7vfYu_cSlWdLAxkdJvCE-4CE_YUtBn384Qn1E7ULzRRJW85UoczSTbi3Vn1uIVjgl-E8H7DaGSYckCPAkUGAoJ_guLvLPRZ2bhqlByR_Qq4P0uil8hMWzY3F3LhDPbE3eAmRTHBv3fTB=w1173-h782-no
Edited by legacybt
  • Like 1
  • Moderators
Looks like an awesome list, the only thing I would wonder about is how much the stock intercooler will be holding you back.
With a VF52 probably not much, and it will stay cooler in the pits while autoX'ing.
Not currently in stock :(
  • Moderators
even with a vf52, a larger TMIC will flow better and make more power, more reliably. bulletproof mod or not,
OP has nice diffs in that trans.
Yeah, like I said--"not much". Didn't say it wouldn't make a difference to switch to an aftermarket option, but the stocker with plastic endtanks DOES have heatsoak benefits in autoX situations. Fulton's stock intercooler was generally cooler than my Perrin when we were sitting around with the cars running waiting for our own runs.
Either way though, 100% agree on a really nice pile of parts. OP: nice build, look forward to following along :)
It'll never handle like a 944.
Haha no it won't. Lift-throttle oversteer isn't quite the same as power-on oversteer on ancient all season tires. :rolleyes:
That being said, having the solid intermediate shaft instead of the stock rubber damper one - coupled with the whiteline steering bushings and misc chassis braces should at least bring some of that feel into the equation. 245/40/r17 star specs (or comparable) should keep things interesting too!
Yeah, there were a couple considerations for staying with the stocker. Heat soak was one, but my engine also has 115,000 miles on it so pushing it closer to the reliability limit isn't high on my priorities.
I have an arduino-based intercooler spray project on the back burner right now too, which should combat that heat soak pretty nicely.
Wow, It's rare that someone posts a future mod list like that and then actually has all the parts to deliver!
Welcome to the world of a mechanical engineer with too much time and just enough money
Edited by legacybt
I'm a fellow ME. I have the opposite problem though. I'll be lucky if I get my snow tires off this year. :lol:
Haha I'm loving the free time I have after graduation. I know it won't last forever.
BUILD UPDATE
Before I made my first post, the trans, diff, axles, brakes, turbo, exhaust and shifter were out of the car.
A la this (picture taken with new UP and Turbo in)
http://legacygt.com/forums/attachment.php?attachmentid=182982&stc=1&d=1400562826
The STI Brake booster is installed, DW 740cc injectors are installed, Whiteline steering rack bushings are in, and the STI intermediate shaft is installed as well. The Grimmspeed uppipe is installed, and the VF-52 was installed for a while...
And then I spent part of the weekend replacing vacuum hoses and oil lines. My engine looks like this now:
http://legacygt.com/forums/attachment.php?attachmentid=182983&stc=1&d=1400562826
Lesson Learned: Apparently the OEM turbo oil feed / AVCS valve line isn't an easy install. I searched beforehand and couldn't find any walkthroughs, and now I understand why. Intake manifold, TGV, Coolant crossover and numerous vacuum/electrical connections later it's finally installed. Had I known, I would have left the original one in place. There goes a couple days :spin:
Reinstallation will have to wait until new gaskets come in.
Interesting build project. I have autocrossed mine several times since 2008. With some suspension parts, it now has neutral handing instead of understeer. Overall, it is a huge and heavy car to autocross! I can beat some miatas but the ones with hoosiers and good drivers beat me.
  • 2 weeks later...
the legacy can be a winner in ESP class nationally with the right mods and driver. That much is fact.
I won't be classed in ESP unfortunately. Far from it - I think I'll be in SM. I don't expect to be competitive, I'm just looking to make my Legacy as fun as possible around the course!
loving the first parts pic ...
now im sure someone could have warned you about those oil feed lines ... had you asked lol!.
Haha yeah, if only I had asked about those oil lines..
Minor update, I didn't have much time to work on the car. The parts are in to put the top half of my engine back together though!
Rear diff and axles are in, and new hubs are installed all around.
http://legacygt.com/forums/attachment.php?attachmentid=184208&stc=1&d=1401688114
This was pretty toast:
http://legacygt.com/forums/attachment.php?attachmentid=184209&stc=1&d=1401688114
Edited by legacybt
With upgraded turbo & front diff, you'll be in SM. I showed up to my first (only) autox classed as SM and the only competitor was a Cadillac coupe on BFG R1 slicks. To say I was outclassed was an understatement.
If you can find a Whiteline ALK-M kit, that will help your turn-in. PUtting on the Cusco under-body braces will stiffen up the back alot. Adding the Whiteline/SpecB rear suspension bits will help as well. Wagon tends to oversteer pretty quick. However, if you can keep your foot planted you can drive it out on sticky tires. On all-seasons, you'll have to lift.
I've been drooling over your wagon for a while now - it's hawt. Looks like a blast to drive!
I've been considering the ALK kit, but budget is a major constraint for me. I'm keeping close enough to stock ride height (1" drop) that it's not totally necessary, and more of a want-to-have that I'll add somewhere down the road.
The same can be said for the spec b bits - I know how important unsprung weight is but I can't justify another $1100 (Canadian Premium) to save 7ish lbs per rear corner. If something comes up locally for much cheaper, though....
I picked up some BNIB JDM Sti lateral links and a whiteline positive power kit the other day. Hopefully they should help the sloppy rear end I have now (along with some Tarmac 1 coils pending purchase!).
Gire (in Vancouver) was selling some suspension bits awhile back, might drop him a line.
The Cusco braces will have more to do with stiffening the rear than other stuff.
For the Tarmac 1, you'll find they are soft. When I talked to them, they were offering "spirited driving" rather "autox" settings. If you are going after an autox car, I would get your suspension tuned for that rather than DD. Otherwise, its a waste of money. You can always spin the selector to "soft" to make up for the harsher ride. Also, spend the money on a good corner-balance, which is what makes c/o worth the money. I would tune in quite a bit of forward rake to keep the front planted and it will mean less delay waiting for the weight transfer to the rear (which slows your exit from a corner).
I'll add the braces to the list, I have to save up for some better rubber. Unfortunately my budget is maxed for the time being.
Those coils are where the "compromise" part of this build comes in. In reality this is a DD, and a lot (95%) of my non-commute driving is just that - spirited. I spend too much time on rough pavement (Duffy Lake Road, anyone?) to justify a full auto-x setup. Spring rates on the tarmacs are still higher than the epic springs that I'm running now, and the added travel will be very welcome - hence the relatively high ride height. A corner balance is definitely in the books.
A few years down the road when I have the space I'll probably grab a pre-modified miata for just that. Until then..
if you have $1600 US lying around, I have 235/40/17 BFG R1 mounted on Enkei PF01 17x8 that fit perfectly. Stick like nothing you've ever used.
Haha I was eyeing those a while back. I'm on the lookout for some 18" rims without rubber, and 17" streetable auto-x rubber (a la starspecs) without rims.
Wut? I have never seen a Legacy at a national event in the midwest. Let alone heard of one competing nationally.
I took mine to a couple national events. mostly in the northeast. At the 2011 NJ Prosolo, if i hadn't snapped axles on the second day i was ready to be in trophy contention. was only lightly off the pace on the right side course and was ready to throw down the second day. And this was against the likes of Sam Strano and Sam Krauss Also in 2008, at the finger lakes prosolo, my Co-drive put down the single fastest ESP time there but ran out of chances to do it 1 more time to take the win. ended up in 4th, only 6/10ths back from the combined time lead. and those were the only 2 national level events i took it to. I have consistently beat the 2013 prosolo ESP winner at local competition.
My LGT was very competitive on a national level. if i had gone for fender modification and wide tires, it would have done some serious business. The car is very capable and you can get it below 3200lbs with simple mods. my car was 3277 with the stock seats and battery.
Edited by whitetiger
  • 3 weeks later...
Quick update before a serious weekend of wrenching
I got me some tires (nitto nt-01)!
http://legacygt.com/forums/attachment.php?attachmentid=186341&stc=1&d=1403892876
http://legacygt.com/forums/attachment.php?attachmentid=186340&stc=1&d=1403892876
Installed rear diff inserts and JDM sti lateral links, along with rear brakes
http://legacygt.com/forums/attachment.php?attachmentid=186342&stc=1&d=1403892876
Got the exedy lightweight flywheel and oem sti clutch installed
http://legacygt.com/forums/attachment.php?attachmentid=186343&stc=1&d=1403892876
I also finished installing transfer case bearings in the transmission, it's ready to drop in this weekend!
