98quiksilvergt Posted October 20, 2010 Share Posted October 20, 2010 Here's a couple pics of my cam gears. One side is right on. The other is off. The upper cam appears to be right on. The lower is off. Does it look like one tooth off to you? http://i226.photobucket.com/albums/dd104/thrty5thsc/7bca03af.jpg If I line the mark up here^ then the two below will be off. No mater what I do, one side is off. http://i226.photobucket.com/albums/dd104/thrty5thsc/7cd47369.jpg Link to comment Share on other sites More sharing options...
GTTuner Posted October 20, 2010 Share Posted October 20, 2010 Yeah, the half tooth syndrome can be a PITA. Pretty common, use the painted lines on the belt and you can't go wrong. Almost every one I do is like this. If it is a used belt, find the painted lines and repaint over them. FWIW, the "Subaru" marking should be read left to right (from the front of the vehicle) as reading a book when you install the belt. Link to comment Share on other sites More sharing options...
subikid90 Posted October 20, 2010 Share Posted October 20, 2010 Mine looks the same. I tried a million time to get it on and it wont work. When I took my old one off it was this way and it ran good, put the new one on the same way and it is still fine, well kinda lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 20, 2010 Author Share Posted October 20, 2010 I just had my water pump replaced about 2 weeks ago. It's leaking again. I haven't removed the belt yet. This is just what I found when I pulled the covers off. The car does run good like this. It sucks that it won't line up! Lol the belt has about 20k on it. Link to comment Share on other sites More sharing options...
TbirdMan Posted October 21, 2010 Share Posted October 21, 2010 yeah, looks like a half tooth at most, perhaps to account for a bit of belt stretch? Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 21, 2010 Author Share Posted October 21, 2010 Well it's back together. Runs the same and marks are the same. Thanks guys!!! Link to comment Share on other sites More sharing options...
