Blackwrx02 Posted September 4, 2011 Share Posted September 4, 2011 Just got into the Wife's 05GT this afternoon and there was no cold air to be found. Didn't seem like the compressor was coming on. Did a bit of reading here but still not sure. Compressor clutch is not turning when AC is on full manual and set to 65 degrees. Does not ever cycle. Just wondering if I can get away with replacing only the clutch and if there are parts available just for that or if a compressor has to be purchased just for the clutch parts. Thanks Link to comment Share on other sites More sharing options...
charlie_sheen Posted September 5, 2011 Share Posted September 5, 2011 does it screech really loud after being on for a few minutes? thats how you know its specifically the clutch Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 5, 2011 Share Posted September 5, 2011 Did you check refrigerant charge, is it full? Link to comment Share on other sites More sharing options...
Blackwrx02 Posted September 5, 2011 Author Share Posted September 5, 2011 Car had a screeching noise but was not really that loud. Could here it at idle but that was it. Ac was fine one day (by subarus poor ac standards) and now not blowing anything but hour air. Link to comment Share on other sites More sharing options...
Wrench Posted September 5, 2011 Share Posted September 5, 2011 Check the A/C relay in the underhood fuse box. My A/C suddenly stopped working and it was a bad relay not sending power to compressor coil. Swap out one of your fan relays and see if your compressor turns on. Just make sure you put the fan relay back so your car doesn't overheat. The dealer will tax about $39 for a new relay. I got one from Autozone for about $7.00. The guy there matched it up to another relay that had the same power output and configuration. If you have a test light check for power at the coil plug on the vehicle harness before you swap out relays b/c if your coil is shorting it will fry your fan relay and any other relay you try. Link to comment Share on other sites More sharing options...
Blackwrx02 Posted September 5, 2011 Author Share Posted September 5, 2011 Good info. Will check relay and refrig charge. Link to comment Share on other sites More sharing options...
frank_ster Posted September 5, 2011 Share Posted September 5, 2011 refrigerant low.. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 7, 2011 Share Posted September 7, 2011 Does your A/C pump click (cycling on and off) Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 11, 2011 Share Posted September 11, 2011 Have you figured out this issue? Link to comment Share on other sites More sharing options...
minitech Posted September 12, 2011 Share Posted September 12, 2011 Also check the for power going to the compressor. Link to comment Share on other sites More sharing options...
PaulFWMotorsports Posted September 14, 2011 Share Posted September 14, 2011 If refrigerant is low, HP hose or o rings suspect. Throw some ac gauges on and measure the pressures. That is the best way to determine ac faults. Link to comment Share on other sites More sharing options...
Blackwrx02 Posted September 14, 2011 Author Share Posted September 14, 2011 It was nearly empty of refrigerant based on the can I have with a gauge. Not ideal to measure I know, but I put quite a bit in and so far it has been holding and blowing as cold add it ever has. Thanks for all the help. Link to comment Share on other sites More sharing options...
PaulFWMotorsports Posted September 14, 2011 Share Posted September 14, 2011 Remember, when the 134 leaks out, it is allowing air into the system. Most likely, the A/C high pressure hose...from the compressor to condenser...needs replacing. Link to comment Share on other sites More sharing options...
frank_ster Posted September 17, 2011 Share Posted September 17, 2011 ^ i don't think much is getting in .. even if the system is completely empty it still has the same pressure as atmosphere. so a tiny pin hole wont let a lot of air into the system. fyi with the new refrigerant it only needs 1 can to fill the system. from what i was told new refrigerant is mostly propane! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
