erickrocks1126 Posted April 14, 2015 Share Posted April 14, 2015 If yes, is it worth it? Pics of your install? Apparently my search skills are weak. The internets has plenty of vids/pics of this installed/used on other makes models, but can't find any on the 2nd gen Leggy specifically. Want to see it set up on one of our cars and get a gauge on how you like it. Thanks! Link to comment Share on other sites More sharing options...
Osei Posted April 14, 2015 Share Posted April 14, 2015 Only used it to flush. I did not leave it attached, Hence no pics. It worked well, you do need some hose clamps. O. Link to comment Share on other sites More sharing options...
erickrocks1126 Posted April 14, 2015 Author Share Posted April 14, 2015 Only used it to flush. I did not leave it attached, Hence no pics. It worked well, you do need some hose clamps. O. If I read the directions correctly, it has you cut into one of the hoses to use the T-tube provided. In reading some of the reviews of the kit, others replaced the T-tube with a connector tube, citing that the one with the kit is cheaply made and not durable enough to leave in. Did you end up using a connector tube to "reattach" the hose after you took the T-tube out? Link to comment Share on other sites More sharing options...
Osei Posted April 14, 2015 Share Posted April 14, 2015 What I did was use a small section of hose to go between the water pipe and the heater hose. then flushed and removed this section of hose and the kit when finished. O. Link to comment Share on other sites More sharing options...
