Ari_OutbackWagon Posted September 7, 2012 Share Posted September 7, 2012 I put in a Sachs clutch kit a few months ago when I swapped in a new engine. The master cylinder ended up leaking so I replaced it. Now the clutch engages incredible low, like 1" off the floor. I'm used to driving with it using the whole throw. It feels kinda sticky too since there a lot of spring in the other 2" or so that is left after it engages. Is there an adjustment I'm missing? Is it because of an aftermarket master cylinder? Very annoying. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 7, 2012 Share Posted September 7, 2012 I'm guessing you may still have air in the system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted September 7, 2012 Share Posted September 7, 2012 I agree, also have someone press the pedal while you look at hos the slave cylinder moves. And check how much play you have between slave and clutch arm. Nothing wrong with a Sachs clutch, just be aware that you need to double-check to make sure that the movements are right and you didn't forget a spacer or so. Link to comment Share on other sites More sharing options...
