gcallahan Posted June 11, 2014 Share Posted June 11, 2014 I am rebuilding a 2.5 ready to install the pistons. But the oil ring groove on the piston is smaller than the ring size. The research I have done shows the oil ring to be 2.80 mm. My piston groove only measures 2.03 mm. Anyone ever had this before? 2.5 from an 06 Impreza. Thanks G Link to comment Share on other sites More sharing options...
Osei Posted June 13, 2014 Share Posted June 13, 2014 Sure you have the right rings, and that you are in the 3rd position? O. Link to comment Share on other sites More sharing options...
gcallahan Posted June 16, 2014 Author Share Posted June 16, 2014 Right rings no. Looks like some WRX's show a 2.00mm oil ring. Not sure why this NA engine would have turbo pistons. Link to comment Share on other sites More sharing options...
Osei Posted June 16, 2014 Share Posted June 16, 2014 Checking opposedforces. there is some crossover in piston rings. ie the same rings are used in the turbo as in the NA. Check with a dealer for exact and correct info for your engine. http://opposedforces.com/parts/impreza/ O. Link to comment Share on other sites More sharing options...
zstalker Posted July 2, 2014 Share Posted July 2, 2014 https://www.google.com/url?sa=t&source=web&rct=j&ei=woqzU8vYM42GogSk-oHICA&url=http://www.gjparts.com/products/pistons%26rings/NPR2008Book_catalog.pdf&cd=2&ved=0CB4QFjAB&usg=AFQjCNEcHmB0SIkYgsOrqdzWXW0bGwF3dg&sig2=wkV-GkXQCnWoDUJOG15tXQ See if that helps. There are two different. 2.5L piston types, with different ring thicknesses. Erik Link to comment Share on other sites More sharing options...
gcallahan Posted July 2, 2014 Author Share Posted July 2, 2014 Thanks zstalker, very helpful. Link to comment Share on other sites More sharing options...
zstalker Posted July 2, 2014 Share Posted July 2, 2014 Btw, NPR is the brand of piston rings Subaru uses and sells through the dealers, so you can just find the right set part number and get them on ebay. Link to comment Share on other sites More sharing options...
