mr_silas Posted November 30, 2012 Share Posted November 30, 2012 starting to get the good ol clunk! so my question is what STOCK subaru struts will fit my car. 05-2012 lgt? Spec-b? 02-12 Wrx/Sti? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 30, 2012 Moderators Share Posted November 30, 2012 why do you want to stay stock? Probably cheaper to just go with aftermarket--kybs or koni inserts. spec.b shocks will work too. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mr_silas Posted November 30, 2012 Author Share Posted November 30, 2012 cheaper and i was afraid after market ones would be more of a rough ride. My LGT is my DD and my Wrx is my play car. So i want it to be as comfortable as possible lol. How do kybs and koni's feel compared to stock? Link to comment Share on other sites More sharing options...
alegend90 Posted November 30, 2012 Share Posted November 30, 2012 Subbing for an answer, as I'm in the same boat. Just a hint OP, the suspension section has tons of good info, and you'll probably find some opinions over there. That's where I'll be heading now! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 30, 2012 Moderators Share Posted November 30, 2012 The konis are adjustable, and I've been told that you can actually adjust them to be softer than stock if you want. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
cypher0117 Posted November 30, 2012 Share Posted November 30, 2012 ideally all struts do is control the rebound of a spring and don't affect the ride harshness. Springs are what affect that the most. If you want cost savings, just get the Kyb struts and be done with it. They are slightly stiffer than stock (which will help control the car's natural underdamped suspension) and they are way cheaper than koni's. Link to comment Share on other sites More sharing options...
MrTris Posted November 30, 2012 Share Posted November 30, 2012 Legos. See Suspension forum. Link to comment Share on other sites More sharing options...
ttnio Posted November 30, 2012 Share Posted November 30, 2012 ideally all struts do is control the rebound of a spring and don't affect the ride harshness. Springs are what affect that the most. If you want cost savings, just get the Kyb struts and be done with it. They are slightly stiffer than stock (which will help control the car's natural underdamped suspension) and they are way cheaper than koni's. ^ Well said. Also,take a ride on one with Koni's or,other aftermarket set ups, if possible. Correct me if I'm wrong,springs dont wear out. Aftermarket springs and struts are there for a purpose. Performance gain and they lower the geometry on the height of the car. Myself,I would go KYB's...on the other hand,there is nothing wrong in choosing OEM's. Link to comment Share on other sites More sharing options...
mr_silas Posted December 1, 2012 Author Share Posted December 1, 2012 thank you guys for all the input. now i have to find some people with both and compare rides. so does no one still know which struts will fit my car? out of all years LGT, WRX and STI Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 1, 2012 Share Posted December 1, 2012 there is a right up on what fits and what doesn't in the suspension part of the forum. i don't have time to find it but I'm sure you could. Link to comment Share on other sites More sharing options...
xero287 Posted December 3, 2012 Share Posted December 3, 2012 Only LGT Struts will fit your car. Link to comment Share on other sites More sharing options...
MrTris Posted December 3, 2012 Share Posted December 3, 2012 so does no one still know which struts will fit my car? out of all years LGT, WRX and STI No, we all know. You're the only one that doesn't. I get the whole "aks and ye shall receive" bit, but, the information is in front of you -- read it. If you want to modify your car (the right way) you should first learn to read, research, investigate, and then make choices appropriate for your application. Otherwise, you're just throwing money at your car. And while that's not a bad thing -- would you rather be the guy that builds horsepower, or the guy that buys it? Choose your own adventure, YMMV, blah blah blah. Link to comment Share on other sites More sharing options...
cypher0117 Posted December 4, 2012 Share Posted December 4, 2012 Only LGT Struts will fit your car. ^^ that if you don't buy OEM and don't want to spend a lot of money get these: http://www.infamousperformance.net/servlet/the-270/KYB-GR-dsh-2-Subaru-Legacy/Detail http://www.infamousperformance.net/servlet/the-1568/KYB-GR-dsh-2-Subaru-Legacy/Detail also, don't buy used struts unless you can verify they are low miles and/or great condition Link to comment Share on other sites More sharing options...
CousinLarry Posted December 4, 2012 Share Posted December 4, 2012 I just purchased some new KYB GR-2's online for $95 shipped for BOTH. Haven't put them on yet though. Link to comment Share on other sites More sharing options...
Wagonation Posted December 4, 2012 Share Posted December 4, 2012 I just purchased some new KYB GR-2's online for $95 shipped for BOTH. Haven't put them on yet though. Good deal. Where did you get them from? Link to comment Share on other sites More sharing options...
