ZX2Fast Posted August 31, 2015 Share Posted August 31, 2015 I'm putting BC BR coil-overs on my car and wondered if I could spin the top of the fronts around too use the adjustment for caster since we have a camber bolt installed already. I did some searching and read some stickies and see no mention of it. I've got a set of the Whiteline caster LCA bushings but from what I gather, these cars benefit from more caster. Link to comment Share on other sites More sharing options...
ZX2Fast Posted August 31, 2015 Author Share Posted August 31, 2015 Just my luck, the sticker on it says 03-08 Legacy but the front mounts are too small too fit on my 2005 LGT. Part number is "F-04" but the number listed for my car on the BC site is "F-04 BR". The rear fit fine, looks like I'm just having crappy luck with this car. Now I get to go back outside and put the stock struts back in, in the dark. Link to comment Share on other sites More sharing options...
ZX2Fast Posted September 1, 2015 Author Share Posted September 1, 2015 I'm still in an Escort state of mind. Can't do that with 3 bolt holes. Link to comment Share on other sites More sharing options...
ras06LGT Posted September 8, 2015 Share Posted September 8, 2015 You can swap the rear-most bushings on the lower control arm for ones that add 0.5 degrees of caster if you haven't looked at that yet. Not a ton, but it helps. Link to comment Share on other sites More sharing options...
ZX2Fast Posted September 9, 2015 Author Share Posted September 9, 2015 I already have that bushing set too put in along with the roll-center kit. Link to comment Share on other sites More sharing options...
boxkita Posted September 9, 2015 Share Posted September 9, 2015 if you are installing coil-overs, you get most benefit by having them corner balanced. The "more caster" is more noticeable in spirited driving (autox/lapping). Using the WL ALK is more than enough for street. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
scoobyscoodle Posted September 12, 2015 Share Posted September 12, 2015 You could rotate the top hats to get more caster, but you're probably going to want more than the -1 degree of front camber to go with it, and that's all the bolts usually yield. Also, the sweet spot for me has been 7 degrees of caster, beyond that and your steering will get really vague and slow, as well as increasing the load on the power steering pump. The best solution is a camber plate that gives you an extra degree of caster built in, but then still allows for camber adjustment. That, combined with the WL ALK kit is what I'm running. 7 degrees of caster and -2.5 front camber. Link to comment Share on other sites More sharing options...
