EpicRasta Posted September 14, 2012 Share Posted September 14, 2012 Does anyone else have this problem? I've searched and haven't found any other complaints, so its probably just me. I have a FMIC and I'm still using the stock throttle body coupler with t-bold clamps. At high RPM's the stock coupler keeps popping off. I've tried hair spray as well. Should I be using a silicone coupler instead? If so, what size? I've read that the 2.75 is too small, and my 3" is too big. Link to comment Share on other sites More sharing options...
ripemeat Posted September 14, 2012 Share Posted September 14, 2012 quick google search: http://legacygt.com/forums/showthread.php/cannot-get-oem-throttle-body-hose-stay-188398.html Link to comment Share on other sites More sharing options...
EpicRasta Posted September 14, 2012 Author Share Posted September 14, 2012 Thanks ripemeat, but that doesn't give any actual solutions based on my reading... other than there a pink dot on where the stock hose should go. Did I miss something? Link to comment Share on other sites More sharing options...
ripemeat Posted September 14, 2012 Share Posted September 14, 2012 you should not be using the stock coupler with a fmic, rather an appropriate silicon hose. Link to comment Share on other sites More sharing options...
Spec B Posted September 14, 2012 Share Posted September 14, 2012 ^ +1 - the size is 2.75" Link to comment Share on other sites More sharing options...
EpicRasta Posted September 14, 2012 Author Share Posted September 14, 2012 Ok, sounds good. Thanks for the input folks! Link to comment Share on other sites More sharing options...
dr_sharp Posted September 14, 2012 Share Posted September 14, 2012 derp lol Link to comment Share on other sites More sharing options...
kongzilla Posted September 14, 2012 Share Posted September 14, 2012 How high of a boost are you running? Link to comment Share on other sites More sharing options...
