j255c Posted June 28, 2008 Share Posted June 28, 2008 What are symptoms of a failing fuel pump. Currently my car has extreme hesitation issues at anything about 4500 rpms it bucks and feels like its misfiring almost, i replaced my plugs thinking that was the cause and it was not. Anyone have any idea? Thanks, Jeff 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
ddavis Posted June 29, 2008 Share Posted June 29, 2008 Sounds like it could be a injector issue. From my experience when a fuel pump goes bad it will just stop working. It usually runs or doesnt. Does the car idle normal? Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 the car idles normal after reaching operating temp, but when it first starts up it runs like crap for about 10 seconds, just barely holding idle well enough to keep it from stalling, then works itself out. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
ddavis Posted June 29, 2008 Share Posted June 29, 2008 Did it start after filling up a tank of gas by any chance? Ive managed to pick up bad gas a couple of times in my camaro and it had the same problems. Studdering all over the place and having issues on start up. Just a thought with the way gas prices are going lately, wouldnt suprise me if bad gas was lurking around. Other then that I image you would get a cell if one of your injectors is bad. I had 2 walbro pumps go out on me and when I turned the key on you could here the pump make some unusual noise before I cranked it. Then I tried to start it and got nothing. Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 so if the pump fails the entire car just wont run? I mean my walbro pump makes a whirring hum sound when it starts, thats normal. Maybe fuel pressure regulator? 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
ddavis Posted June 29, 2008 Share Posted June 29, 2008 Yeh, if your pump is bad your car just wont turn over. Almost like you dont have any gas in the tank, since it cant get fuel. I prob would try some datalogging to see if the car might be leaning out while carefully keeping a eye on your numbers. Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 oh its definately not lean, dumping way to much fuel right now. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Scrad Posted June 29, 2008 Share Posted June 29, 2008 If your fuel pump is bad the car will not start. Best way to check this is to turn on the key and wait to start the car you will hear the pump hum. If you don't hear it, it is bad. Also if it won't start and you have someone kick your fuel tank and then it magically fires up, it is a bad pump. Another sign its bad is if the car runs fine under steady acceleration. If you let off the gas or trying to idle it will run like crap or die. You said it idles like crap until it gets warmed up. Might be a head gasket leaking coolant into the cylinders. Coolant is then burned off and it runs fine. Check your coolant levels or pull a plug out after the car sits over night and see if it is wet. Otherwise it sounds like it is something electrical or fuel related when things get warmed up. Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 i just pulled all the plugs and replaced them, my coolant level is fine, the car has never overheated in its lifetime. This car recently :spin: 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 much better performance after re-tightening the inlet/air filter god damn this car is picky when it comes to running right. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
ddavis Posted June 29, 2008 Share Posted June 29, 2008 wait, the filter was the problem? Link to comment Share on other sites More sharing options...
j255c Posted June 29, 2008 Author Share Posted June 29, 2008 seemed as if there was a post maf/ inlet leak. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
qikslvr Posted June 30, 2008 Share Posted June 30, 2008 It's possible. I've got into the habit of checking and re-tightening all my band/T clamps every week. I have a couple that work loose once in a while. Let's kick this pig! Link to comment Share on other sites More sharing options...
Darkness of Death Posted June 30, 2008 Share Posted June 30, 2008 if your fuel pump is on it's way out, it would feel like it's got no power, rough idle.. that''s what i had when my fuel pump was going out on me - svx, not lgt ~ Link to comment Share on other sites More sharing options...
rchayes21 Posted May 27, 2015 Share Posted May 27, 2015 My fuel pump is going out.... How difficult is it to install a new one? Link to comment Share on other sites More sharing options...
Th3Franz Posted May 27, 2015 Share Posted May 27, 2015 It's not so bad. search the install threads on the forum here. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
benena Posted August 31, 2015 Share Posted August 31, 2015 Just upgraded to dw65c. Probably didn't need to. Stock fp, never changed the filter, 115,xxx k. Man I knew I'd regret not taking a picture... if only I did. That damn filter did it's job alright, lots of crap on it. Also the housing was littered with flakes and stuff (sorry I really should have snapped a pic, I just wanted to be done with it asap). I think I'd have been fine just swapping out filter, but did the whole dw65c (cheap and easy). If you guys have the hesitation symptoms (rpm can't hold when braking or going from a stop, before the car warms up), try and changed the filter at least (like $10), the filter works (actually filters stuff... a lot of stuff!) and its super damn easy. Look up the guide and follow (remember to relieve fuel pressure by taking out the fuel pump fuse and start the car, let it idle and die out, a guide on nasioc didn't mention that.) Link to comment Share on other sites More sharing options...
whitrzac Posted September 1, 2015 Share Posted September 1, 2015 Where can you find a lgt fuel filter for $10? Cheapest ive seen is $70 Link to comment Share on other sites More sharing options...
makemoves71 Posted September 18, 2016 Share Posted September 18, 2016 So was this because of the filter? Sent from my SPH-L720T using Tapatalk Link to comment Share on other sites More sharing options...
