John494 Posted June 29, 2012 Share Posted June 29, 2012 Where can I get a stereo dash kit for an 03 legacy gt? I can't find one anywhere:spin: Link to comment Share on other sites More sharing options...
Heedz Posted June 29, 2012 Share Posted June 29, 2012 Look on crutchfield assuming you have a 3rdgen unless you're foreign. Link to comment Share on other sites More sharing options...
stevenva Posted June 30, 2012 Share Posted June 30, 2012 http://www.metraonline.com/vfg It's pretty much just a pocket. The kit wont be needed if you have an existing pocket with a single din radio. Your car does not have a "typical" kit made for the dash. You will be mounting the new radio "ISO" mount. http://www.installdr.com/TechDocs/999015.pdf All aftermarket radios come pre-drilled and screws supplied to be ISO mounted. If your factory radio was a double din, (or a stacked radio/cd) then you would need the kit. If your new radio is double din, then no kit is needed. Regardless of which way you go, You must use the factory radios side mounting brackets and transfer them to the new setup. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
John494 Posted July 1, 2012 Author Share Posted July 1, 2012 That would all be wonderful if I didn't have the 6 disk changer model which is a double din already (and has a pocket under it), and I am getting a single din replacement Link to comment Share on other sites More sharing options...
stevenva Posted July 1, 2012 Share Posted July 1, 2012 OK. I searched and found out a photo of your stock setup. If you already purchaced your single din radio then you will have to get the pocket kit and have 2 pockets below. http://www.metraonline.com/part/Mitsubishi_Subaru_Dash_kit_98-8999 I would urge you to get a double din radio if you haven't got your new radio yet, It'll just look better. You can get good deals on new, mainstream models from http://www.sonicelectronix.com/cat_i62_double-din-car-stereos.html I have used them before and was happy with their service. Next, I searched and found (for you) how to R&R your radio. Search link is at the top right of this forum. http://legacygt.com/forums/showthread.php/help-replacing-stereo-02-legacy-wagon-65115.html PS. I didn't appreciate your sarcastic response when I was trying to help you. Everything I said before is true for your car model. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
John494 Posted July 2, 2012 Author Share Posted July 2, 2012 Ok Thanks. And p.s that wasn't sarcasm directed at you, that was desperation after searching for three hours to find one with no luck. Everything I've tried to change about my car I've had to either make what I wanted from scratch or ghetto rig into the existing stuff and I was expecting to have this be a simple thing, but it's not unless I want to spend more. Link to comment Share on other sites More sharing options...
