a.lim Posted November 7, 2007 Share Posted November 7, 2007 theres an unusual clicking noise coming from my engine. the noise gets really loud inside the cabin and when i press on the clutch the clicking goes away. any ideas? Link to comment Share on other sites More sharing options...
whitetiger Posted November 7, 2007 Share Posted November 7, 2007 How many miles on the car? does it happen when you are idling with the clutch engaged? have you tried opening the hood and listening for it to pinpoint location? Link to comment Share on other sites More sharing options...
a.lim Posted November 7, 2007 Author Share Posted November 7, 2007 car has about 18,000 miles on it. when i'm idling with the clutch engaged it makes the noise. thats when its most audible. Link to comment Share on other sites More sharing options...
Omegared1 Posted November 7, 2007 Share Posted November 7, 2007 Not 100% certain, but I suspect a bad throw out bearing if its the clutch. Had the same problem with an old 95 dodge avenger. A loud clicking and whirring noise that would go away when the clutch is pressed, or until the car is hot. Let me know if that's what you are experiencing. Link to comment Share on other sites More sharing options...
a.lim Posted November 7, 2007 Author Share Posted November 7, 2007 Not 100% certain, but I suspect a bad throw out bearing if its the clutch. Had the same problem with an old 95 dodge avenger. A loud clicking and whirring noise that would go away when the clutch is pressed, or until the car is hot. Let me know if that's what you are experiencing. yea thats pretty much what im experiencing.. would this be covered under warrenty? Link to comment Share on other sites More sharing options...
sexylegacy Posted November 7, 2007 Share Posted November 7, 2007 This should be covered under your powertrain warranty because it is a bearing, not the clutch which would be normal wear and tear. Link to comment Share on other sites More sharing options...
sexylegacy Posted November 7, 2007 Share Posted November 7, 2007 Mine hums very quietly when I let the clutch out in neutral, but I'm still going to keep an ear on it to see if it gets louder. Link to comment Share on other sites More sharing options...
a.lim Posted November 8, 2007 Author Share Posted November 8, 2007 im now wondering if i should return my car to stock before i take it in to the dealership. anyone have any experience with renick subaru in fullerton, ca? Link to comment Share on other sites More sharing options...
a.lim Posted November 8, 2007 Author Share Posted November 8, 2007 i mean, a throw out bearing wont affect the exhaust system, nor suspension, nor motor. so as long as my clutch hasnt been replaced by an aftermarket one i should be fine im thinking.. Link to comment Share on other sites More sharing options...
lhsa Posted November 8, 2007 Share Posted November 8, 2007 it sucks, but take off your mods. most stealerships will use any reason to deny warranty coverage. Link to comment Share on other sites More sharing options...
schneiks Posted November 8, 2007 Share Posted November 8, 2007 I came in here about to post a similar problem...my car is at 17,600mi right now and I hear a noise coming from the front left (when looking from the front of the car) part of the engine. It sounds like a knocking noise, thought maybe I had a bad belt but they look fine. It also speeds up a little when driving - but does not get extremely fast. It seems to go away after giving the car at least 15 minutes of driving. I drove it 30 minutes to the dealer and it was gone - then it came back later that day after my car sat while I was working. Any ideas? I'm going to need to leave my car at the dealer and that sucks. Link to comment Share on other sites More sharing options...
a.lim Posted November 9, 2007 Author Share Posted November 9, 2007 yea i can definitely confirm its something loose though. when i barely press on the clutch the rattling goes away. im definitely taking this into the dealership to fix it. Link to comment Share on other sites More sharing options...
2.5GTurbo Posted November 9, 2007 Share Posted November 9, 2007 It sounds like your throw out bearing. My throw out bearing went out at 59,500 miles. The power train warranty is through 60,000 but the throw out bearing is only covered through 36,000 (at least on an 05 it is) so you should still be fine. Subaru of Santa Monica did the work on mine. I have been fully stage II since 8,000 miles and I’ve never had any problems with warranty work. I had to pay this time because the warranty was up and they have to drop the trans. and disassemble the whole clutch to get to the throw out bearing. My clutch still had about 10,000 miles on it when they took it apart but I was already paying them to tear it down and put back together so I opted to replace it. A normal clutch replacement at the dealership goes for $1500.00!!! I had to pay for that plus the new throw out bearing, and a new engagement fork that failed with the throw out bearing. Plus Subaru had to replace the clutch assembly case as it cracked when the throw out bearing failed, luckily I had that 500 miles left on the power train warranty as that part goes for about $750.00... In the end with the clutch, pressure plate, fly wheel, throw out bearing, new fork, clutch assembly case, and a 60,000-mile service it was $2300.00 and almost three weeks out of my car!!! (Evidently the clutch case was a special order item.) I would be mad, but I’ve been modified for over 50,000 miles and all I’ve ever had to pay for with this car is regular service and huge Chevron bills!!!! Way better to me than my 1.8T was... You shouldn't have any problems man, just be prepared to be out of your car and into a crappy rental for a while! Civic Nation REPRESENT!!! Link to comment Share on other sites More sharing options...
MerkLGT Posted May 30, 2010 Share Posted May 30, 2010 I have 116,000 miles, about 60K on a new clutch, throw out bearing and flywheel. I have recently started experiencing a loud clicking noise when I start accelerating and especially when coasting, in gear, from about 35 mph and down, stopping around 10 mph. It sounds like a metal baseball card stuck in the spokes of a bike. The frequency of the clicking is constant, but louder at slower speeds. The sound goes away completely when the clutch is depressed or the car is in neutral. There is no sound at idle. Does this sound like a bad throw out bearing as well or something else? Link to comment Share on other sites More sharing options...
ProjectS15 Posted May 31, 2010 Share Posted May 31, 2010 sounds more along the lines of a bad wheel bearing. Link to comment Share on other sites More sharing options...
MerkLGT Posted June 1, 2010 Share Posted June 1, 2010 I thought that at first too, but the sound is more centralized to the middle of the engine compartment. The frequency of the clicking is not related to vehicle speed which makes me think it's not a wheel bearing. It's a constant clicking. Link to comment Share on other sites More sharing options...
