DOHCEJ22E1 Posted October 26, 2017 Share Posted October 26, 2017 Okay, so Photobucket had an incident in which they changed things up and so whatever photos I had posted on here were lost forever, because I am sure as shit not paying them $400 a year. So without further delay, we shall start from the beginning. Here is my 1996 Subaru Legacy LSi that I had purchased last year for $500. The first mod, a 420A ignition coil, was done. spiced things up some from the diamond coil. Also added a radio when there was none. In my quest to improve the car, I aimed at the grille, primarily out of boredom. The completion of the Loyale style grille. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Sitting sometime during the early winter. Addition of the Big 3. The snow is gone and she finally got plates. ECU hunting and testing. Ran a stock L 2.2 ECU for a bit, as it proved to be the best for running and conserving 87 octane. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Enjoying her a little more while I could, but around this time, the original 25D began to die. A 97 Legacy Outback Limited is approached for it's ECU (7X), which later proves to be an awesome instrument. Also approached a 420A Eclipse and found a goodie... What I left the boneyard with that day... Shots of a random Legacy GT and my LSi. She passed emissions. Got some LED's for the license plate lights. Final snowstorm that the 25D propelled me through before it died. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 A trip to the boneyard yields this nice EJ222 block for about $140. Proceeded to clean up a bit. EJ222 crank gear and stuck sensor. Water pump removed. Broken crank gear sensor. More cleaning. Ej222 oil pump removal. MSD 8239 coil on and working fine. Another thing that must be discussed is that the 85 ECU I had earlier was from a '99 Outback. It did not work with me airbag and evap system, and so while it will plug right in and run, it will always throw a check engine light. The 9P ECU is what came in the car and is the prime reason why the manufacturer called for 91+ octane. It sucked at adapting for sure, which is why it was replaced. The 7X was the best ECU as it adapted well and communicated with everything. I am still running it now. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 If anyone wanted to know, some Mini Cooper Supercharged ignition coils will also work as viable performance upgrades, as they are 36kv and similar to the MSD 8239. Radio and trim upgrade. A good friend's Legacy. More straightening up the 222 block. Came home with a goodie (black Outback hood). 222 block cleaned up some more with straight pins removed. More goodies. Stock baffle installed. Moroso oil pickup installed. Magnetic oil drain plug. "Str8" pinning for increased head gasket and head security when torqued. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Detailed EJ205 oil pump with new filter installed and new EJ257 tensioner bracket. Grimmspeed intake manifold spacers, 2006 Legacy thermostat, and 1lbs VMS lightweight crank pulley. Showcase of EJ20D intake port size. EJ20D head internal layout is shim over, if anyone was wondering. Str8 pin meets 222 head gasket. EJ20 turbo water pump vs N/A 2006 Legacy water pump. Passenger side head and STi roller kit installed and torqued down. Driver side of the block awaiting head. Head installed and belt mock. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 New bolts and 257 coolant crosspipe installed. 22D almost ready. Longitudinal. STi oil pan installation. Edging so closer... Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 26, 2017 Share Posted October 26, 2017 Nice dude! Whenever anyone asks me about how to do a similar hybrid I find your threads and send them your way. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Received a present goodie. The rebuilt EJ25D has finally died for good. The trick that made the dying 25D last as long as it did. It is time for removal. 1996 EJ25D and 1997 EJ20D intake ports are about equal size. All accessories removed from 25D. Gotta grind down intake manifold edges on the big plenum 25D manifold to fit the 257 coolant crosspipe. Coolant crosspipe sensor will work. 2 out of 3 wires for the Phase 2 sensor match the Phase 1 wiring. Installation pretty much explains itself after you get the Phase 2 connector with extended wiring. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Nice dude! Whenever anyone asks me about how to do a similar hybrid I find your threads and send them your way. Haha, thank you. Wait until you see the end result as I slowly bring this up to speed. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 22D is almost ready. Secondary power steering bracket doesn't line up with the bolt hole with the 257 crosspipe, so I removed it. everything now fits perfectly. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Skip a little past the installation as I lost those pics permanently. The EJ22D is installed and pulling hard for an EJ22. At this point, I had not discovered the power level and so was just enjoying the engine for what it is. The Legacy itself had gone through a few changes. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 My exhaust setup: UEL's w/2.5in catback to unknown muffler. My buddy's 22D-T powered Legacy wagon. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 On that same day. 22D alive and well. Sometime after. 10k milestone of ownership, 8k miles after the 22D installation. Closer to the present. The name on the plaque is my instagram name. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Upgraded to WRX Momo wheel and Outback SUS Safari interior. The day of the ECS Performance dyno testing 10/18/2017. On the rollers... Dyno graphs. Youtube videos. Link to comment Share on other sites More sharing options...
momalley Posted October 26, 2017 Share Posted October 26, 2017 Is that an Outback front bumper? If so, what year. I really like how that looks with that hood. Nice build. Shows the hard work and dedication. Thanks. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Is that an Outback front bumper? If so, what year. I really like how that looks with that hood. Nice build. Shows the hard work and dedication. Thanks. Thank you. The bumper covers, grille, and front bumper brace are all from a 99 Outback SUS. My foglights aren't wired up yet, but that will be changing real soon. The difficulty of building these is low once you get your hands on a few of them. I continue practice at junkyards periodically to keep the skills sharp. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Here is what was done to my car during the high compression EJ22D project for those who need a summary: Engine: EJ20D heads, valves, and valve springs (1997). EJ25D big plenum manifold (1996 LSi stock). EJ25D wiring harness (1996 LSi stock). EJ253 water pump (2006). EJ222 block and head gaskets. EJ205 oil pump (detailed). EJ257 coolant crosspipe and sensor. EJ257 timing assembly and extra roller. EJ257 oil pan. EJ257 Moroso oil pickup. Gates blue teflon belt (DO NOT BUY THESE). Tomei timing belt guide. VMS lightweight crank pulley (1lbs). Grimmspeed intake manifold spacers w/bolts. All new seals and bolts. Self milled heads via sanding. Lightly ground intake ports. Refreshened and seated valves. 4 extra straight pins for head gasket and head security (Str8 mod). Custom head bolt torque sequence (2lbs tighter on the last 3 rules). 1st generation Subaru Legacy engine cover and brackets. EGR disable. Ignition: Started with Dodge 420A coil, then upgraded to MSD 8239, then further up to the Accel super coil for the SRT-4. Body: 1999 Outback SUS bumper covers, front bumper brace, and grille. Lights: JDM RS front headlights with HID system. Sequential front turn signal lighting. Rear USDM w/VNT red paint. Exhaust: Early UEL w/2.5in catback to unknown muffler (we'll call it the Noemi Spec C). Electronics: WRX radio. Raizin voltage stabilizer. New Sony xPlod rear speakers. Interior: 1997 Outback SUS Safari woodgrain trim (actual laminated wood). Steering: 2004 STi steering rack. L&E Fabrications steering wheel to rack conversion joint. Rallitek steering rack poly bushings. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 26, 2017 Author Share Posted October 26, 2017 Comparison of the MSD 8239 to the Accel super SRT-4 coil. Accel coil installed. How the car looks today. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 27, 2017 Author Share Posted October 27, 2017 Update: The Accel coil continues to do well. For the money, it seems to be an even better bargain than the MSD 8239, but there is a catch and I will find it. The overall feel of the car is balanced and I am certain that I would give any stock 3rd gen Legacy with an EZ30D a great challenge above 3500rpm. The project shall continue, as my next move will be to update the intake into something a hell of a lot better. I have reached the limit of the intake pipe when it comes to turbulence. Will also beef up the fuel system a bit to bring in fuel where it is needed so I won't run that lean on the top. Link to comment Share on other sites More sharing options...
RustyRuu Posted October 27, 2017 Share Posted October 27, 2017 that 2.2d-t build is pretty cool just out of curiousity what is that little cluster thing where the A/C would be. there's a gauge and some tubing? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 28, 2017 Author Share Posted October 28, 2017 that 2.2d-t build is pretty cool just out of curiousity what is that little cluster thing where the A/C would be. there's a gauge and some tubing? You're talking about my buddy's wagon 22D-T? That is an FMU/RRFPR setup for the parallel fuel rail mod. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 31, 2017 Author Share Posted October 31, 2017 Project Esperanza Log: The rear end began to pull yesterday, and so I performed the "dime" test, which yielded the rear tires being low in depth and tread. To prevent center differential damage, a 10a fuse was put into the FWD fuse slot and now, I am driving around in FWD mode until I can get new rear tires with my check this Friday. However, though the strain was greatly lessened, I still felt a smidge of pull and inspected the rear diff to find that it is slowly leaking at the drain plug. I will inspect further in the morning to see what the issue is. There is no wheel bearing damage or play, but the right side wheel provides significant resistance compared to the left. I will also note that in FWD mode, the power delivery is exceptional, and I have even lesser difficulty at all getting up to high speed. 90mph comes up surprisingly and fuel economy is better +3mpg city and +2mpg hwy. I will likely convert the FWD fuse into a toggle switch as I have done so many others to have that extra modicum of control. The plan next is to create an advanced intake of some kind to bring even more air in on the low after I solve the rear differential issue, and following that will be as many fuel mods as I can pull off to get this engine at it's maximum on the stock ECU before I eventually get a good piggyback for tuning. Link to comment Share on other sites More sharing options...
Setnev Posted October 31, 2017 Share Posted October 31, 2017 50/50 Mod with FWD Mode FTW! Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 1, 2017 Author Share Posted November 1, 2017 50/50 Mod with FWD Mode FTW! Definitely in the plans and cards. First, FWD mode, then 4WD mode. Changed out rear diff fluid and replaced it. Rear diff now spins nice and smoothly on both sides, so now all is well. Just have to remain on FWD until I get new rear tires, and then I can put my AWD back on. FWD does allow me to move faster in a straight line (MUCH faster), but the AWD provided a level of athleticism not found in FWD models. Link to comment Share on other sites More sharing options...
