LGT_18_34 Posted April 15, 2013 Share Posted April 15, 2013 Okay so i've been having this really weird phenomenom with my car, (05 gt limited) occasionally when i am coasting right before coming to a stop the car kinda shakes. The engine doesnt sputter at all the car runs perfectly fine. It only does it occasionally but i have no idea what the problem is. Right before coming to a stop theres just a slight shake. Anyone else who has had this problem or any thoughts please comment. Thanks Link to comment Share on other sites More sharing options...
InnocentGuns Posted April 15, 2013 Share Posted April 15, 2013 Lot of stuff posted on the forums. do a search. fuel, shake, maf, ect. good luck Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 15, 2013 Share Posted April 15, 2013 lots of threads so search.. but nutshell is this Clean MAF senor Vacuum test Clean OCVs or replace them Replace IM to TGV orings Compression and Leakdown test Boost Leak Test Link to comment Share on other sites More sharing options...
Max Capacity Posted April 15, 2013 Share Posted April 15, 2013 It must be a 5mt, right ? Is the shake in the chassis or engine ? How often do you drive the car ? Could you have rusty brake rotors ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGT_18_34 Posted April 15, 2013 Author Share Posted April 15, 2013 It must be a 5mt, right ? Is the shake in the chassis or engine ? How often do you drive the car ? Could you have rusty brake rotors ? It feels like its more in the chasis than the engine itself shaking. Its a daily driver that i drive between 20-30 miles a day during the week. I have just over 100,000 miles on the car. And im not sure on the brake rotors, i'm unfortunately mechanically illiterate for the most part. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted April 15, 2013 Share Posted April 15, 2013 So, auto or manual? Link to comment Share on other sites More sharing options...
LGT_18_34 Posted April 15, 2013 Author Share Posted April 15, 2013 So, auto or manual? Auto Link to comment Share on other sites More sharing options...
Max Capacity Posted April 15, 2013 Share Posted April 15, 2013 Oh its a auto. When you said coasting, I thought you meant you pushed in the clutch and put the tranny in neutral, like I do. You could have a transmission issue. Have you checked the fluid level ? You may want to stop by a Transmission shop for a free road test. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 15, 2013 Share Posted April 15, 2013 Okay so i've been having this really weird phenomenom with my car, (05 gt limited) occasionally when i am coasting right before coming to a stop the car kinda shakes. What gear are you in? D (4th) OD (5th). I'm thinking the lockup part of the torque convertor is hanging up. Does it do it in D (4th) & OD (5th) or just OD (5th). How a bout (N)? When was the last time your A/T was serviced? I would PM ClimberD@HexMods His valve body thread. http://legacygt.com/forums/showthread.php/valve-body-mods-giant-leaps-forward-160101.html He should be able to help you out if it's a tranny issue. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
mandarin Posted April 15, 2013 Share Posted April 15, 2013 What fluid are you running in the slushbox? I have a similar issue that I am hoping will be resolved when I finish exchanging the PO's incorrect fluid with Subaru's HP. Try searching for auto-tranny fluid issues. Link to comment Share on other sites More sharing options...
noLie Posted April 16, 2013 Share Posted April 16, 2013 I've had a similar issue.However there were times where my car just felt like it was on the brink of stalling. (I also own a 5EAT) In my case, what happened was that the purge valve failed to open and close. This means there were no leaks, hence no CEL. I replaced it for about 50-60 dollars and it's been running fine since then. Link to comment Share on other sites More sharing options...
LGT_18_34 Posted April 16, 2013 Author Share Posted April 16, 2013 I just checked the trans fluid and levels were normal, and it does when the cars in first gear only right before coming to a complete stop. I also noticed today that it only seems to do it when im on the brakes for a prolonged period of time, (slowing from about 40mph or higher). If i pump the brakes I couldnt seem to get the car to do it.. Thanks for all the help by the way guys Link to comment Share on other sites More sharing options...
Max Capacity Posted April 16, 2013 Share Posted April 16, 2013 It's a 05, by chance have you replaced the o-rings at the intake manifold to the TGV's. They are known to cause idle issues. When you see the new o-rings next to the old one's, you'll understand why they cause vacuum/idle issues. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mr. Sinister Posted April 16, 2013 Share Posted April 16, 2013 Shift to neutral the next time you try to reproduce the problem. It'll help rule out the transmission if the problem goes away. I agree with Hammer Down. I think it's a torque converter problem, which is why I wanted to know if it was auto or manual. Link to comment Share on other sites More sharing options...
rob-2 Posted April 16, 2013 Share Posted April 16, 2013 It'd start with something easier than having him go through a host of time intensive tests. 1. Check tranny fluid levels - a given 2. Check for oil in intake - remove BOV and look in - can cause knock 3. Ensure you have good gas in the car 4. Watch your RPMS. What happens just before the stop that causes the shake? If on #4, a lot of people will point to o-rings. I had this problem and fixed it without o-rings. My fix was: 1. Clean MAF 2. Replaced PCV Link to comment Share on other sites More sharing options...
TheBlackPearl Posted April 16, 2013 Share Posted April 16, 2013 It's not the transmission downshifting to first gear while in sport mode, is it? Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
