blkrs5 Posted April 19, 2013 Share Posted April 19, 2013 I left to Puerto Rico And let my little bro use my spec B. He loves it.he loves it and trying to be helpful he wanted to do an oil change and put rotella t6. That's what I always use. But he spills a little oil on the engine and somehow decides my engine has a leak somewhere. So he adds Lucas stop leak. BUT he doesn't drain a quart he adds the entire quart of Lucas to an engine full of rotella t6 5w-40. Now the turbo jitters when trying to spool and its throwing out white smoke. What can I do. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 19, 2013 Share Posted April 19, 2013 Do another oil change, see what it sounds like after that. If its still noisey pull the DP and check for shaft play. Link to comment Share on other sites More sharing options...
2slo4me Posted April 19, 2013 Share Posted April 19, 2013 Id def change the oil... the lucas might be to thick. Link to comment Share on other sites More sharing options...
stuck686 Posted April 19, 2013 Share Posted April 19, 2013 add a quart of lucas stop leak to ur brother Link to comment Share on other sites More sharing options...
lingling1337 Posted April 19, 2013 Share Posted April 19, 2013 So you're saying its on the same oil and stop leak? Definitely change the oil first and see what happens Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2013 Share Posted April 19, 2013 add a quart of lucas stop leak to ur brother This get's my vote ! 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted April 19, 2013 Share Posted April 19, 2013 add a quart of lucas stop leak to ur brother Love this!! Link to comment Share on other sites More sharing options...
