robot8282 Posted January 16, 2015 Share Posted January 16, 2015 I would have used the search because I figure this has been asked, but it isn't working for me. I'm just curious as to what would be a good set of spacers to get for my car with stock wheels? I don't know much about them, but I don't want to get anything super cheap that will crack when I hit a bump. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 16, 2015 Share Posted January 16, 2015 best - don't use one better - hub centric spacer, it's just a piece of aluminum Unless you are talking about bolt on spacer/adapter, then look into how the stud is pressed into the spacer after investing in some good spacer, you are half way there for a set of wheels. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted January 16, 2015 Share Posted January 16, 2015 An understanding of the goal would be good. If you're trying to clear upgraded brakes, a measurement would help... 3mm? 5mm? You can find hub centric spacers on Amazon. If you're going for stance, try NASIOC forums, brah. Tits mcgee Link to comment Share on other sites More sharing options...
robot8282 Posted January 16, 2015 Author Share Posted January 16, 2015 I'm not really going for stance, brah. I just want to push out my stock wheels a little so that they are flush with the car. Like I said, I don't have much knowledge about them, which is why I'm asking. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted January 16, 2015 Share Posted January 16, 2015 Is spacers cracking a prevalent problem? I really don't know. And I don't know whether it would be catastrophic if they did. I suspect not. The use of any wheel spacer puts additional strain on the hubs/bearings. So it's best to try to keep them as thin as possible. So your first step, I would think, is to figure out what would put the wheels flush with the car. Also... consider using longer studs versus installing spacers with studs pressed in. Tits mcgee Link to comment Share on other sites More sharing options...
turboboost Posted January 19, 2015 Share Posted January 19, 2015 H&Rs were recommended to me by AZP, but I'm only running 3mm in the rear. If you want your stock wheels to be flush, you'll need 15-20mm spacers + extended studs, which will strain your hubs/bearings for sure. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted January 19, 2015 Share Posted January 19, 2015 20mm brah. Tits mcgee Link to comment Share on other sites More sharing options...
turboboost Posted January 19, 2015 Share Posted January 19, 2015 Herrafrush Link to comment Share on other sites More sharing options...
rchayes21 Posted January 20, 2015 Share Posted January 20, 2015 Ya. 20mm adapter is gonna get the look I think you're going for. Look into Perrin. They have really good hubcentric and spacers and adapters Link to comment Share on other sites More sharing options...
Whatisit Posted January 20, 2015 Share Posted January 20, 2015 check out these folks http://www.motorsport-tech.com/ they use alcoa aluminum (semi truck wheels) and made in the good ole United states of America!. i have these and use them on my stockers to clear brembo's. I dont track or drive aggressivly; i understand that it strains the bearings (humble brag photos for you) http://i129.photobucket.com/albums/p206/95tegRS/DSC_0518.jpg http://i129.photobucket.com/albums/p206/95tegRS/DSC_0515.jpg Link to comment Share on other sites More sharing options...
lil_z_33 Posted January 30, 2015 Share Posted January 30, 2015 ive been running h&r 15mm hub centric spacers on my lgt with stock rims and aftermarket for 4-5 years...even at the track...no issues if installed correctly... Link to comment Share on other sites More sharing options...
