mjandmj Posted October 23, 2015 Share Posted October 23, 2015 My brake light is on and flashing along with the traction control disabled light. Its a 2010 legacy EJ253. Any ideas?????????? Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted October 26, 2015 Share Posted October 26, 2015 Bad abs sensor/hub or broken wire to one ? It may have a OBD code set that can tell for certain what's up. Link to comment Share on other sites More sharing options...
iyalla Posted November 1, 2015 Share Posted November 1, 2015 Isn't this a loose gas cap issue? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 3, 2015 Share Posted November 3, 2015 I would've guessed low brake fluid, but I look forward to learning the cause. Link to comment Share on other sites More sharing options...
2manysubies Posted November 6, 2015 Share Posted November 6, 2015 Concur with wheelbuilder_25. the traction control system uses the ABS system to modulate the wheel brakes to maintain traction. Applying a brake to the spinning wheel induces power transfer to the other side of the vehicle, front and back are indep. of each other. You don't have a limited slip in the front, you may in the rear but it is unlikely. I'm not a 2010 i guy specifically but some things follow through MY to MY. R/Mac Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted November 9, 2015 Share Posted November 9, 2015 Also - which brake light ? The ABS light, or the one that just says Brake ? If its the plain brake light, check the fluid first. Link to comment Share on other sites More sharing options...
