dombek2k7 Posted May 1, 2010 Share Posted May 1, 2010 i have an 05 lgt... ive been waiting for a friend to help install, well warm weather is here and i want my bass back! I know there is no aux on the back side of my stock head unit. I purchased a line output converter to hook up on my my rca's. WHERE the hell do i need to install this behind my deck?? Everything else im good with... but help.... please Link to comment Share on other sites More sharing options...
dease42 Posted May 1, 2010 Share Posted May 1, 2010 There's a wiring diagram somewhere on here, try to search for it... or check the vacation pics. If you're installing the amps in the trunk, you can splice into the rear speakers, otherwise if you pull out the head unit, you can wire directly into either the front or rear speaker outs... Let me see if I can find my wiring harness instructions, might be able to give you the "colors"... Here you go, based on the 05 metra kit (for the non-auto climate controls, but I'm pretty sure the pin-out is the same... might want to check the vacation pics for verification): 12v ignition --- Red 12v Batt/Memory --- Yellow Gound --- Black Pwr Antenna --- Blue Amp Turnon --- Blue/white Amp Ground --- Black/white Illumination --- Orange Dimmer --- Orange/white Right Front + --- Gray Right Front - --- Gray/black Left F + --- White Left F - --- White/Black Right Rear + --- Violet Right Rear - --- Violet/Black Left Rear + --- Green Left Rear - --- Green/Black Like I said, might want to verify, but hopefully that will help Link to comment Share on other sites More sharing options...
dombek2k7 Posted May 1, 2010 Author Share Posted May 1, 2010 gotcha..... so as long as i can get to my rear speaker wires i can tie my converter into that Link to comment Share on other sites More sharing options...
John M Posted May 1, 2010 Share Posted May 1, 2010 Not to sound mean but if you don't know how to wire it up after receiving the info from the above post, you may want to get help from someone with car audio experience. FWIW, the rear speakers in a LGT are in the doors, not the deck, so there's no shortcut there. Link to comment Share on other sites More sharing options...
dombek2k7 Posted May 1, 2010 Author Share Posted May 1, 2010 John M, dont worry about wiring when it comes to me.. this is the first time ive decided to keep my stock deck... ok so yeah ill be ripping the deck out and wiring from the back side.. dease42 thanks for the help pal Link to comment Share on other sites More sharing options...
