Evofai Posted December 1, 2013 Share Posted December 1, 2013 So for the past month or two whenever i start my car on a cold start i get a loud screeching sound coming from my engine and i have no idea what it could be. I feel like it has something to do with my power steering because whenever i try to turn my car when im at a complete stop i get the screeching sound and it sounds like its grinding. If i start to actually drive and turn my car then i dont hear the screeching sound. Any suggestions on what to do or what the problem is? If you want to hear what it sounds like i found a video that sounds exactly like my car. [ame=http://www.youtube.com/watch?v=beGZcdKh2xY]Ford Probe screeches on cold start - YouTube[/ame] Just the screeching sound of when the car has actually started. I have a 96 legacy sedan Link to comment Share on other sites More sharing options...
Headtrauma89 Posted December 1, 2013 Share Posted December 1, 2013 Loose belt Link to comment Share on other sites More sharing options...
sunny5280 Posted December 1, 2013 Share Posted December 1, 2013 Most likely cause is a loose belt. However I recently experienced a squealing noise from an idler pully for the timing belt as it was beginning to seize. Though that wouldn't be dependent on moving the steering wheel. Something to keep in mind if you rule out the other belts. Link to comment Share on other sites More sharing options...
spooln30 Posted December 2, 2013 Share Posted December 2, 2013 Loose belt or a worn belt will cause these noises. GL Link to comment Share on other sites More sharing options...
